hi,all
I'm not sure ,the SAMYANG 35mm Lens , Mount : Olympus/ Four Thirds, are this lens will work fine in gh2? or i need a adapter?
becous i will buy the :
SAMYANG 35mm F1.4 ED AS UMC Lens Samyang 85mm f/1.4 AS IF UMC
and all of him the Mount Olympus/ Four Thirds.
sorry for my English, and thanks
you will need a Four Thirds > Micro Four Thirds Adaptor
now this mount will not work whiteout a Micro Four Thirds Adapter. maybe if i take the canon or Nikon mount is better in re-sale in future. and adapter for canon EF to mft . Right?
It is hardto understand that you mean. @Sph1nxster provided link to the adapter that will work with any 43 lens on any m43 camera. Period.
@Vitaliy_Kiselev thanks.
Sure. You can also get the Nikon F or Canon EF version (plus a good adapter). It´s maybe even better - As you said: For resale OR if you want to try out a focal reducer in the future for example. If you want to be on the safe side, get the Nikon edition (as there is actually only the "RJ lens turbo" available for Canon EF to micro 4/3) and you don´t need the electronics for this Samyang lens (also not for the 24mm F1.4 and the EXCELLENT 16mm F2.0 for example) ^^.
@Tscheckoff thank you and appreciate your response.
now i thank i will take the two samyeang : samyang 85mm t1.5 cine lens \ canon EF samyang 35mm t1.5 cine lens \ canon EF
and this adepter from mtf services (link: https://mtfservices.com/canon-ef-micro-43-adaptor )
thanks all.
Well. You don´t need to get the quite expensive MTF services adapter. Also cheaper ones are working well (i am happy with my Big-is adapters for example).
