Cake 2 vs cake 3 settings
  • differences between cake 2 and cake 3? in yalls opinion what are the pros and cons of each patch. I see 3 doesn't use b frames is 3 higher quality all things being equal? or is 2 just as good with the benefit of lower file sizes? Thanks for any advice
  • 2 Replies sorted by
  • I installed cake 2.3. Seems to be working fine spanning fine. Im.using a fast 64 gig card and at 24h i get 2 hours of rec time and at 720p 2 and a half hours. Does this seem right? Seems like at a modedt 44 bit i should get alittle more time than that and shouldnt there be more of a difference between the two settings than a half hour? Thanks
  • Use existing settings topic.
