New Sekonic meters
nice
That looks very interesting considering what @shian says about exposing in zones. The software included determines the DR of your cam and safes it for later use so you can measure your scene and check if it is within that range. I like!
This guys really need to start selling software for smartphone and small hardware addon. :-)
Yep!
A light meter is an invaluable tool on a digital set when you try to keep a constant ratio between key/fill/background etc. Having a monitor doesn't help you too much in that case. If you shoot the reverse shot to another shot you have taken a couple hours earlier, you probably won't be able to recreate the same ratios just by looking at your monitor.... A light meeter helps you to keep everything consistent from one shot to the next, even if many hours or even days passed in-between filming the shots...
