Two issues:
1.When using PTOOL my virus scanner BITDEFENDER kicks in and stops the process, finding it a potential danger
And? Do you want us to discuss idiots who wrote your antivirus software?
Otherwise, start with something from http://www.personal-view.com/talks/categories/hack-top-settings
While not related to PTool, whenever you need to try an application, you may try virtualisation technics. You may use Sandboxie to run the application sandboxed or even use Virtual Box or something similar to create a virtual OS.
Overkill? Yes, could be, depending on what you need.
Very pleased with the latest Sanity parameters. They solved my problems of spanning and the writing errors. Highly recommended. Thanks.
