Sony Radio Mic - UTX-B1 replacement antenna
  • Hi,
    got an older set of wireless mics, the antenna on the transmitter has come loose and now I've lost it, can anyone suggest a cheap fix for the antenna? it looked like it was just fine copper filaments within a rubber tube, after it had come loose, as long as it was fixed into the rubber holder on the mic body it worked ok,
    Cheers
  • 1 Reply sorted by
  • @Vitaliy_Kiselev , wrong category! can you move to gear>sound many thanks
