Hey guys, I wanted to show you guys how the Wooden Cage works with the GH3, I did forget to point out 2 important features on the cage because I wont be using them, one is the fact that it comes with a small plate that can help prevent your camera from slipping if you use a follow focus and the 2nd one is that you can also use the hotshoe as another point to tighten or secure the camera. In this post http://www.personal-view.com/talks/discussion/7535/gh3-loose-hot-shoe-pictures#Item_1 I show the reason I had to get a cage, and how weak the GH3 hot shoe is, I hope this video helps someone else to make a decision on whether to get this cage or not. Take care everyone
Out of my price range, but I definitely like this. More universal for future bodies and modular to upgrade. I never liked the bulk of the square ones that had no more access to the hand grip, so this is a bonus all around.
Humm...I have the Carryspeed Viewfinder VF-4 . It adds a baseplate beneath the camera . Watching your video I dont think will be enough room to fit the gh3 with this baseplate . Can you make it a little higher ? Or I do need the medium size ?
@labalbi I think it would be a tight fit with the small version, although remember that the rod on the side is adjustable, and you can still go up and down a little bit but it might not be enough, better to go with the medium one, another great thing about this is that you can simply add a longer rod and still use the same cage.
thanks . the baseplate is included ? its easy to attach in a manfrotto head ? Thanks
