I'm trying to figure out if I can copy hacks to SD cards and switch between versions. I'm wondering for instance if I can load a hacked patch on SD and then bring a stock firmware card with me on a shoot, switch back and forth. I'm assuming you can't do this because you would have to increment the version in Ptool each time?
I don't increment the version hacks. All are named GH2__V11.bin. To keep track, I have a folder and put each patched version in different folders. ie Cluster Nebula 6, Spizz. Then copy them to separate SD cards. If you carry a laptop with you, you may not need separate SD cards.
yes you can. you have to make sure version increment is checked so cam doesnt check for increments. your only issue is having a full battery when updating each time
