I managed to use ptool to save a "new" version of firmware and installed it on the camera. I have different patches/hacks on all the green buttons A - J (except F - i don't know why this happened). can i switch between patches/hacks once they're loaded on the camera, or can i only load one patch per "new" version of firmware? if multiple hacks are loaded onto the camera, how do they appear in the menus?
thanks, g
You cant switch between hacks in camera. You can only use one patch in camera by updating it. You have to choose a patch on ptools and create the updated firmware everytime. Best recommendation is get some cheap small sd cards and put a patch on each one if you want to change the firmware out and about. Although I really recommend just finding one which you are happy with and stick with it. Driftwoods Apoc now or the Sanity patch is a good start.
