As you may know, GTX 680 and GTX 670 cards are based on same chip (later has one block turned off).
And it has harware H.264 encoder. No, not CUDA based.
All Kepler GPUs also incorporate a new hardware-based H.264 video encoder, NVENC. Prior to the introduction of Kepler, video encoding on previous GeForce products was handled by encode software running on the GPU’s array of CUDA Cores. While the CUDA Cores were able to deliver tremendous performance speedups compared to CPU-based encoding, one downside of using these high-speed processor cores to process video encoding was increased power consumption. By using specialized circuitry for H.264 encoding, the NVENC hardware encoder in Kepler is almost four times faster than our previous CUDA-based encoder while consuming much less power.
It is important to note that an application can choose to encode using both NVENC hardware and NVIDIA’s legacy CUDA encoder in parallel, without negatively affecting each other. However, some video pre-processing algorithms may require CUDA, and this will result in reduced performance from the CUDA encoder since the available CUDA Cores will be shared by the encoder and pre-processor. NVENC provides the following:
Via: http://www.geforce.com/Active/en_US/en_US/pdf/GeForce-GTX-680-Whitepaper-FINAL.pdf
It could be very interesting to see native support in main NLE for this feature.
Some tests: http://www.guru3d.com/article/geforce-gtx-680-review/6
Faster, colder and greener. This is an Olympic step forward.
I bet on Adobe to get it to work first...
My research indicates that all the 6xx series have the encoder. Thus the GTX650m chipset shipping with laptops...Hmm!
EDIT:- The beta nvenc SDK supported all 6xx series cards. With the latest driver, the license for the beta expires and the release version of the nvenc SDK only activates the encoder on their "pro" cards.
http://arstechnica.com/civis/viewtopic.php?f=6&t=1190620&p=25805955#p25805955
Darn Nvidia!
