I finally got a Fotga brand DP500 with the original mount, not the quick release. You can get them now for ~100$USD. Much better than other FF model out there. Nice and solid. I took it apart and tightened all the screws for the gears as they were a little loose and causing play. The only complaint I have is that the white plastic is the same as the other "cheap" FFs being sold and is NOT compatible with dry erase markers as they stain the plastic. Grease pencils work ok though.
