GH2 Dark section on the sensor?
  • It seems that most of the sensor is somehow too bright, and the section on the right is the only area that is correctly exposed. I was shooting outdoors for the first time and a seemingly random array of my clips have this odd defect to them. I mostly shot 60p that day, and only the few that were shot in 24H are affected. Anyone have an idea of what this is? I've never seen this type of phenomena before.
    Settings: ISO 160 24H 1/60 Cake 2.2 Sandisk Extreme 45mbit/s
    1703 x 955 - 2M
    1701 x 956 - 2M
  • 6 Replies sorted by
  • As far as I remember previous such things it had been bad lens converter.
  • I've had this problem before, it's a light leak from the adapter's release catch. In future, put a piece of gaffer over the hole and you'll be fine.
    To correct my footage, I put a rectangular vignette over the dark area, feathered it and brightened it up to match the rest.
  • @billthebutcher I had the same issue with this footage -
    Ran a few tests and can confirm it is as explained by @vitaliy_kiselev and @rockfall You can confirm it for yourself by putting a canon body cap on and then holding a light near the catch. Should give the same washed out image with a dark line.
  • @rockfall by "release catch" do you mean the lever to take the lens off the adapter? I'm using the Fotodiox Nikon G adapter.
  • my method to identify and close ANY false light sourse:
    attach lenscap
    turn cam ON
    high ISO
    use strong flashlight from any direction
    monitor LCD if any light visible
    identify leak
    close leak with e.g. gafa tape/security laque/paint/chewing GUM your taste/be creative
    do NOT contaminate the inside of cam!!!
    GO and SHOT!
  • Yeah I meant the lever to take the lens off, it's a bit of a design fault!
