Panasonic has already shut down Lumix Club for most cameras last year, and the rest at the end of this month. So, time is of the essence.
I am trying to make an open source replacement server so that the WiFi feature can continue being used to its full extent. It is possible, because one of the first things the camera does is download over http what root certificate it should use. I successfully set up a man-in-the-middle tool with the current Lumix Club server (lumixclub.panasonic.net), but it seems to be different than the old server (lumixclub.picmate.jp) and not provide all of the API's the older cameras need.
I am wondering if anyone has either of the following things:
Thank you in advance.
You are doing very good thing, hope someone could help you.
I think you are better off looking at streaming via the USB Port.
Wifi at 1080p an 4K has issues due to bandwidth limitations.
As far as I know, the Panasonic Apps downscale the images that they transmit over wifi because of this.
It seems to me that they have abandoned the idea because an actual Engineer discovered that the Management Plan was unreasonable from the very start. Although I could be wrong.
