A Dual V-Mount Battery Charger + AC Inverter to expand how you use your professional cine Batteries. Do you need to power a Laptop while you're editing in the field, or maybe charge your Drone batteries while you're off-the-grid? Perhaps even power your Live Stream setup in remote locations. The CAME-TV Power Station / Battery Charger is the perfect accessory to expand the use of your v-mount batteries.
With a variety of output options you can Power LED Lighting, Wireless Video transmitters, Monitors, and more. Dual D-Tap outputs, Dual 12V barrel adapters, USB-A, and a Type-C output, the Power Station is a must-have accessory that expands the use of your cine batteries.
