PR
The APO-Summicron-SL 28 f/2 ASPH.: A state-of-the-art, wide-angle lens for the Leica SL-System
Leica Camera is delighted to launch the first true wide-angle lens for the SL-System, the APO-Summicron-SL 28 f/2 ASPH. This latest addition joins the APO-Summicron-SL series – a lens range renowned for its fast, top-level optical performance and reliable autofocus.
Joining the existing focal lengths of 35, 50, 75 and 90mm in the series, the APO-Summicron-SL 28 f/2 ASPH. features the same dimensions and filter size as its relatives. Its angle of view makes the lens particularly suitable for reportage, interior and architectural photography.
Both the construction and the design of the cutting-edge Summicron-SL series represent the next step forward in the development of lenses for the Leica SL-System. New, extremely precise manufacturing methods and measuring technologies have been developed specifically for the production of these lenses – resulting in more compact dimensions and a considerably lower weight, as well as a truly outstanding imaging performance.
In the construction of the APO-Summicron-SL lenses, particular attention was paid to the prevention of stray light and reflections. In addition to optimising the optical and mechanical design, the developers also reduced unavoidable reflections to an absolute minimum by applying a high-quality coating to the lens surfaces. Thanks to their effective sealing against dust, moisture and water spray, as well as the Aquadura coating of the exposed lens surfaces, these extremely durable lenses can be used in almost any weather conditions without any reason for concern.
As is generally the case with Leica lenses, the maximum aperture is synonymous with the effective aperture. Its maximum aperture – which is large for this focal length and can be used without any loss of image quality – offers additional creative possibilities through the controlled application of sharpness and blur. Consequently, there is no need to stop down to increase the image quality – instead, reducing the aperture is only necessary for compositional purposes. Natural skin tones, soft transitions into bokeh, exceptionally contrast-rich details and edge-to-edge sharpness across a distortion-free image: these qualities are very much the norm for Leica lenses. Thirteen lens elements (three of which feature aspherical surfaces on both sides) in ten groups contribute to a maximum level of image quality even at a wide open aperture.
The APO-Summicron-SL 28 f/2 ASPH. is further distinguished by its apochromatic correction, which is a notable feature in a lens of this focal length. To ensure the optimal correction of chromatic aberrations, the majority of the grouped lens elements feature anomalous partial dispersion and are made of high-quality, specialist glass types whose construction is so elaborate that even Leica’s most innovative production methods are utilised to every inch of their capacity.
The autofocus drive of all Summicron-SL lenses employs extremely robust and high-performance stepping motors with DSD® (Dual Syncro Drive™). This enables the AF to travel the entire focusing range in around 250 milliseconds. At the same time, Leica Camera also takes an innovative approach to manual focusing technology: Summicron-SL lenses feature an entirely new manual focus ring construction in the form of an embedded ring magnet with alternating north-south polarisation. When the ring is turned, the magnetic field changes its polarity. A sensor monitors the status of the magnetic field and sends the data to the main processor. The drive then shifts the lens to the corresponding focusing position based on the angle of rotation and the rotational speed – this, in turn, enables even faster and more precise manual focusing.
Thanks to the L-Mount standard, the APO-Summicron-SL 28 f/2 ASPH. is equally compatible with cameras made by other partners of the L-Mount Alliance that have been equipped with the Leica-developed lens mount.
The Leica APO-Summicron-SL 28 f/2 ASPH is available now at the Leica retail stores (book your virtual appointment here) or online at store.leica-camera.com/uk
RRP: £4,050
