Kinefinity MAVO Edge 8K Camera
    • 44.7-megapixel 36mm x 24mm full-frame CMOS sensor
    • ProRes RAW recording
    • Dual native ISO - 800 and 3200
    • Modes
      • 8K Open Gate up to 48 fps
      • 6K up to 100fps (S35 mode)
      • 5K up to 120 fps (S35 mode)
    • up to 14 stops of dynamic range
    • 12ms rolling shutter in 8K, 9ms in S35 mode
    • Uses KineMAG Nano cards (just repackaged NVMe M.2 SSD
    • Motorized electronic neutral density filter, 0.6 to 2.1 ND
    • IO -
      • Two 3G/1.5G SDI ports
      • Timecode IN/OUT (5-pin)
      • BNC Genlock
      • 12V RS Output (three-pin)*
      • Seven-pin sync port
      • R45 Ethernet port
      • 12V D-Tap Out
      • 3.5mm headphone jack
      • USB-C port
    • 10.5 x 12.1 x 11.9 cm
    • 1.2kg
    • $11,999
    • September 2020 release
    • Preorder at http://www.kinefinity.com/shop/mavo_edge_preorder/?lang=en
    800 x 796 - 80K
    800 x 694 - 69K
    800 x 653 - 49K
  • 2 Replies sorted by
