Manfrotto 500 Hybrid Lightweight Video Tripod
    It has a maximum height of 173.3cm and a closed length of 72.2cm, and features an Easy Link connector to attach anti-rotation accessory arms such as monitors and audio recorders, making it highly adaptable for a variety shooting circumstances.
    It is based on Manfrotto 190 tripod, the MVK500190XV boasts D-shaped tubes to ensure shooting stability and Quick Power Locks that can be locked and unlocked in a single-handed single movement.
    The lightweight 500 Fluid Video Head ensures smooth and precise shots, thanks to the fluid cartridges fitted on both the pan and tilt axis. Its pre-set 2.4kg counterbalance of 2.4kg complements CSC, DSLR and smaller video cameras.
    618 x 877 - 47K
  • 1 Reply sorted by
  • PR
    NEW FROM MANFROTTO – THE 500 HYBRID LIGHTWEIGHT VIDEO KIT
    • A new kit with the hugely popular 500 Fluid Video head
    • Aluminium 3 section single leg tripod based on the 190X model with levelling column for quick set up
    • Easy link equipped with anti rotation to connect external accessories
    Manfrotto, world leader in the photography, videography, imaging equipment and accessories industry, has announced the release of the new 500 Video system. Designed for videographers looking for a video system that is both easy to carry and versatile, the 500 Video System can support small camera systems up to 5kg.
    Market leading technology
    Based on the market leading 190 tripod technology, the MVK500190XV features D shaped tubes which ensure rigidity when you are shooting.
    The Quick Power Locks (QPL) provide a secure locking grip, and can be locked and unlocked with just one hand in a single movement, meaning a quick and easy set up when you need it. Each of the 4 leg angles can be set individually for flexible positioning ensuring that you get the shot you want.
    The innovative levelling column is perfect for smaller camera setups and allows for quick levelling of the head as well as the option to make quick height adjustments for perfect framing. The inclusion of 3 grub screws on the top disc that eliminate movement by locking into the head and a levelling bubble allow for fast levelling on any surface.
    Fluid video head
    The 500 Fluid Video Head is lightweight and ensures smooth shots. The fluid cartridges fitted on both the pan and tilt axis make any shot controlled and precise. With a pre set counterbalance of 2.4kg, it is perfect for CSC and DSLR rigs as well as dedicated smaller video cameras. The snap-lock, sliding QR plate allow the camera and sliding plate to quickly click in the head from above making it quicker and simpler to both click the camera into place, and lift the camera out of the head from above.
    Accessories
    The Easy Link connector can be used to attach anti rotation accessory arms – perfect for external monitors, audio recorders and more. The ability to easily and securely fasten accessories using the Easy Link connector on the tripod plus the additional connector on the fluid head mean that you can rig up your perfect set up with ease.
    With a maximum height of 173.3cm and a closed length of 72.2cm, this latest, high performance kit from Manfrotto is a perfect choice for any videographer looking for an adaptable, easy to use and secure system.
    RRP £359.95. For more information please visit www.manfrotto.co.uk
