Zaxcom is proud to announce Fader Motion Capture (FMC), a feature that records the fader levels and movements made by the production sound mixer in real time into a separate file. The file can be then imported into a post workflow where the fader movements are replicated in the workstation. This time-saving technology allows post production to edit and remaster the location mix without starting from scratch. “Today, many hours of the location mix can be discarded by post as the mix track is being remixed from isolated tracks,” says Glenn Sanders, President of Zaxcom. “Fader Motion Capture will allow the industry to utilize more of the location mix with the added benefits of a fully editable track and saving time.”
How it works
Fader Motion Capture is available on Deva 24 as a standalone recorder or when paired with Mix-16 or Oasis control surfaces. It creates a separate FADER folder containing “.FAD” files found on Deva 24’s recordings. These files can then be converted into AAF files using free downloadable software called Zaxcom Fader Motion Capture to AAF Converter.
Once converted to AAF, the files can then be imported into the workstation. The new files can be added to any timeline where key frames generated by the location mix can be fully edited and remixed. To view the Fader Motion Capture key frames in the workstation change the audio view to “volume”.
Workstation compatibility
Fader Motion Capture is compatible with Media Composer, Media Composer Ultimate, Pro Tools and Pro Tools Ultimate. To use Fader Motion Capture in Pro Tools, users must first import the converted AAF files into Media Composer then export the audio through Media Composer to be imported into Pro Tools for further editing.
Availability
Fader Motion Capture is standard feature on Deva 24 and is currently available in beta release. The Zaxcom Fader Motion Capture to AAF Converter software is both PC and MAC compatible. You can find out more info by visiting http://zaxcom.com
