On personal recommendations and targeting
  • The state of personalized recommendations is surprisingly terrible. At this point, the top recommendation is always a clickbait rage-creating article about movie stars or whatever Trump did or didn't do in the last 6 hours. Or if not an article, then a video or documentary. That's not what I want to read or to watch, but I sometimes get sucked in anyway, and then it's recommendation apocalypse time, because the algorithm now thinks I like reading about Trump, and now everything is Trump. Never give positive feedback to an AI.
    This is, by the way, the dirty secret of the machine learning movement: almost everything produced by ML could have been produced, more cheaply, using a very dumb heuristic you coded up by hand, because mostly the ML is trained by feeding it examples of what humans did while following a very dumb heuristic. There's no magic here.
    Someone who works on web search once told me that they already have an algorithm that guarantees the maximum click-through rate for any web search: just return a page full of porn links. (Someone else said you can reverse this to make a porn detector: any link which has a high click-through rate, regardless of which query it's answering, is probably porn.)
    Now, the thing is, legitimate-seeming businesses can't just give you porn links all the time, because that's Not Safe For Work, so the job of most modern recommendation algorithms is to return the closest thing to porn that is still Safe For Work. In other words, celebrities (ideally attractive ones, or at least controversial ones), or politics, or both. They walk that line as closely as they can, because that's the local maximum for their profitability.
    https://apenwarr.ca/log/20190201
