RICOH COMPANY, LTD. and RICOH IMAGING EUROPE S.A.S. are pleased to announce the launch of the HD PENTAX-FA 35mm F2. Despite its compact dimensions, this high-performance wide-angle lens covers the full-frame image circle of PENTAX K-mount digital SLR cameras.
This new lens is based on the smc PENTAX-FA 35mm F2 AL — a very popular multi-purpose, wide-angle lens used on film-format SLR cameras and is introduced following a thorough review of lens coatings. The high-grade, multi-layer HD Coating applied to the optical elements produces high-contrast images with edge-to-edge sharpness, free of flare and ghost images. Whilst, the highly stain-repellent SP Coating applied to the front surface improves the lens’ usability outdoors. The redesigned exterior matches the design of latest PENTAX K-mount digital SLR models, while its compact, portable body makes it perfect for everyday use.
HD Coating to enhance imaging power
After a thorough review of the lens coatings applied to the popular smc PENTAX-FA35mm F2 AL, PENTAX applied the latest HD Coating* to this lens.
Compared to conventional multi-layer coatings, this high-performance, multi-layer coating reduces average reflectance and improves light transmittance to deliver extra-clear, high-contrast images free of flare and ghost images, even in demanding lighting conditions such as backlighting.
SP Coating to repel stains
Applied to the lens’s front surface, the SP (Super Protect) Coating is highly repellent to water and grease, making it easy to wipe off any stains. This frees the photographer from worries in outdoor photography.
New exterior design to match latest digital SLR models
While retaining the overall size of the original smc PENTAX-FA35mm F2 AL, this lens features a totally new exterior design, similar to that of the latest DA- and D FA-series lenses. This new appearance makes this single-focus lens a perfect partner for latest K-series digital SLR models.
Since this lens retains the aperture ring, it also accommodates many of the functions provided by film-format SLR cameras and older K-mount digital SLR models, making it possible to enjoy photography using a greater range of cameras.
Easy-to-use standard lens
When mounted on a PENTAX digital SLR camera body, this lens provides a moderately wide 35mm angle of view with a full-frame model, or a standard 53.5mm angle of view with an APS-C-format model. Since it provides a natural perspective similar to that of the naked eye, it can be used as a multi-purpose standard lens in a wide range of applications, including snapshooting, scenic photography and portraiture. It also features a minimum focusing distance of 0.3 meters.
Compact, portable design
Weighing approximately 193 grams and measuring a mere 44.5 millimeters in length, this lens has been designed to be extremely compact and highly portable for carefree photography at any location and on every occasion.
Hybrid aspherical optical elements
The lens incorporates hybrid aspherical optical elements to effectively compensate for various aberrations. Thanks to these elements, it delivers extra-clear, high-contrast images from the minimum focusing distance to infinity, and edge-to-edge sharpness even at open aperture.
HD PENTAX-FA 35mm F2 - Price & Availability
HD PENTAX-FA35mmF2 ‐ RRP: £399.99
Available: February 2019
