Sony is pleased to introduce 3 new professional ATOM X SSDmini products designed for use in ATOMOS recorders. As film makers production use of DSLR and mirrorless cameras increase, the new ATOM X SSDmini can easily attach to the Atomos line of products which helps to eliminate the cameras internal compression and time limits. The ATOM X SSDmini snaps off the back and the content is edit ready, stored securely on the SSD drive.
- SV-MGS50/BT 500GB SSD $199.90
- SV-MGS1T/BT 1TB SSD $379.90
- SV-MGS2T/BT 2TB SSD $759.90
- Special design for the Ninja V and fits other ATOMOS products1
- Up to 550MB/s Read Speed and up to 500MB/s Write Speed2
- Certified to support all codecs of Atomos products
- Delivers reliable recording without frame drop out
- Highly durable connector which passed testing of 3,000 times of repeated insertion and removal test3
- Shock Resistance: up to 1500 G / 0.5ms
- Interface: SATA 3 (6Gbps)
- Dimensions: 80.0 X 75.5 X 7.8mm
- Weight: 88g
- Warranty: Three (3) year
