50mm F1.8 II YONGNUO lens for Canon
    Supports USB-free Firmware Upgrade
    Firmware of the lens can be upgraded through camera instead of using USB port, which not only meets the requirements of firmware upgrade and appearance design, but also avoids the incompatibility problems caused by different computer operating systems.(Note: this function needs to be supported by camera)
    F1.8 Bright Aperture
    Maximum aperture F1.8,bokeh effect is easily achieved ,which brings you more fun during photographing.
    New Mechanical Structure, New Coating Technology
    YN50mm F1.8 II has all the product advantages of the last generation. By improving the mechanical structure and coating technology, its focus accuracy, auto-focus speed and light transmittance are increased. Furthermore, it can control backlight ghost and glare.
    Durable Metal Mount
    YN50mm F1.8 II adopts chrome-plated and high-accuracy metal mount. It’s wearable, corrosion-resistant, and highly consistent with the body of the camera.
    0.35m Closest Focusing Distance
    Compared with the first generation, the closet focusing distance of YN50mm F1.8 II is shortened to 0.35m.You can get closer to the object for photography and enlarge the object.
    Focus Modes: Auto Focus (AF) and Manual Focus (MF)
    YN50mm F1.8 II supports auto focus and manual focus. The focus mode can be selected according to practical requirement.
    Focus Distance Indicator is convenient for you to estimate the distance and the depth of field.
    YN50mm F1.8 II has 7pcs of aperture blades, which helps to take picture of circular defocused spots or helps to stop down and take picture of 14-star effect.
    579 x 549 - 40K
    598 x 542 - 52K
    407 x 412 - 27K
