Voking VK-WM220 Features
- Dual channel UHF wireless receiving technology for using two transmitters simultaneously.
 - Double conversion DSP receiving processor for strong anti-mirror interference ability.
 - Professional circuit structure provides low cut function.
 - Dual independent output and MIX output optional.
 - Equipped with headphone output socket for real-time monitoring.
 - Both headphone and recording output volume can be adjusted independently, with memory function.
 - WNCR noise control technology can suppress environmental noise and wind noise.
 - Integrated high-performance audio compander provides a wide dynamic range.
 - Provides up to 100 wireless frequencies to set up multiple channels working at the same time.
 - Supports external power supply, so as to adapt to various occasions.
 - Rugged metal construction for excellent electrical characteristics and mechanical strength.
Voking VK-WM220 Specifications:
- Frequency range: 538-594 MHz
 - Modulation mode: FM
 - Frequcy response: 30 Hz-18 kHz
 - Microphone type: Condenser Omni
 - Channels: 100
 - Frequency control: PLL Synthesizer
 - Transmit power: ≤ 10 mW
 - S/N ratio: >90 dB
 - Power supply: DC 3V or 2pcs AA size batteries
 - Operating time: ≥ 10 hours
 - Operating range: 100 meters at outdoor open area
 - Operating temperature: 0-55 C
 - Store temperature 20-55C
 - Dimension: 896322 mm
 - Net weight: 120g
