I purchased one each.
Pro: lightweight, very flexible, good price, bi-color
Cons: 5600K is 5100K only and a tad greenish. Needs a big battery when mobile powered >160W. Even the small 50W RX-12TD, doesn't power at all with less. It seems the controller draws a lot of power. Doesn't hit airline regulations with the big batteries.
A Shark Fin plate may help with the battery size issues. Adapts two V-mount batteries to one V-Mount so you may be able to use the lower capacity , airline reg batteries. Something like this: https://www.bhphotovideo.com/c/product/359201-REG/Switronix_GP_TS_GPTS_V_Mount_Hot_Swap.html Have no experience with this particular one but have used similar 'Sharkfin' vmount system to power Alexa Mini
@Vitaliy_Kiselev because of the typo (falyon instead of falcon) it did not show up at forum research:-)
@Glenn7 it's quite new on the market. How should I know if it's durable?
I fixed typo, was in video title also.
@Bernie thanks for the hint, I ordered one
though the panel has only 100W it does't power with batteries.with less than 10A /160Wh . Even the smaller 50W RX12 needs this power. Unfortunately these batteries are over the security limit for flight travels. Great value though.
Our BIRTV interview
