18-400mm F3.5-6.3 Tamron Di II VC HLD lens
    559 x 973 - 71K
    650 x 394 - 34K
  • 15 Replies sorted by
    Tamron Announces 18-400mm All-In-One™ Zoom
    We are pleased to announce the latest addition to the all-in-one™ zoom line-up:
    18-400mm F/3.5-5.6 Di II VC HLD all-in-one zoom lens (model B028) in Canon and Nikon mounts The 18-400mm is a new exciting flagship lens that adds to our current line-up and exemplifies Tamron’s all-in-one expertise and the options these great lenses afford photographers of all levels. This new unprecedented all-in-one is positioned as a compact ultra-tele zoom with all-in-one, wide-angle versatility for APS-C cameras. It will target enthusiasts who desire even greater ultra-tele capability for sports, wildlife and more, but also enjoy the versatility of the all-in-one lens for various photographic opportunities. Think of a 100-400mm with portrait, 1:2.9 macro, and wide angle capability for added convenience.
    The 16-300mm will remain in the line for the enthusiast customer also looking for great range and versatility, but from a more compact, all-in-one lens prioritizing wide angle for travel and full range for every-day shooting and more.
    These two lenses, while similar in many ways, offer different choices for the customer from the pioneer and leader of the all-in-one zoom lens category.
    KEY FEATURES:
    The power of ultra-telephoto. The versatility of all-in-one.
    Powerful performance that exceeds your imagination. Introducing the world’s first ultra-telephoto all-in-one zoom with a 22.2X zoom range. Now you can shoot everything from vast landscapes to details of a bird with a single lens. The latest optical design includes a complex series of elements including LD (Low Dispersion) glass and an aspherical lens. Problems like chromatic aberration and distortion are controlled throughout the entire zoom range, resulting in sharp, superior images-whether you’re shooting at wide-angle or telephoto. Capture thrilling close-up action in a snap.
    • World’s first 22.2x ultra-telephoto all-in-one zoom lens
    • 620mm full-frame equivalent telephoto reach
    • VC for confident telephoto shooting
    • HLD means quick, accurate and quiet autofocus
    • 1:2.9 Max. Mag. Ratio for versatile close-up capability
    • Moisture-Resistant Construction
    • Compatible with TAMRON TAP-in Console™, an optional accessory product
    463 x 908 - 106K
    789 x 595 - 107K
  • PR
    Tamron, a leading manufacturer of optics for diverse applications, announces the launch of the new 18-400mm F/3.5-6.3 Di II VC HLD (Model B028), the world’s first ultra-telephoto all-in-one zoom lens for APS-C DSLR cameras, which covers a focal length range of 18-400mm. Since the 1992 launch of its AF28-200mm F/3.8-5.6 Aspherical (Model 71D), Tamron has dominated the all-in-one zoom category and has produced many lenses that cover wide-angle to telephoto zoom ranges. Tamron has now developed an ultra-telephoto all-in-one zoom that extends to 400mm (35mm equivalent of 620mm) and a 22.2x zoom ratio. Packed in a light, compact body (4.8in./24.9oz.)2 is Tamron’s accumulated knowledge and experience for all-in-one zoom lenses, including the most advanced optical and mechanical designs, an HLD (High/Low torque modulated Drive) for the AF system and the Vibration Compensation system. Photographers can now enjoy wide-angle to ultra-telephoto photography using one lens, which is ideal for travel photography and eliminates the need to carry extra lenses. The new Model B028 lens enables photographing a wide variety of ultra-telephoto images including everyday casual scenes. The 18-400mm will be available in the U.S. at the end of July at $649.
    PRODUCT HIGHLIGHTS
    The world’s first3 ultra-telephoto all-in-one zoom lens to achieve 400mm telephoto
    The new Model B028 is the world’s first lens for APS-C DSLR cameras that covers a focal length range of 18-400mm and achieves a zoom ratio of 22.2x. The focal length of 400mm on the telephoto end enables the capturing of ultra-telephoto pictures with the 35mm equivalent of 620mm angle of view. Now, with just this one lens, a photographer can readily enjoy the power of ultra-telephoto to bring distant subjects closer as well as the perspective-flattening effects that only extreme telephoto settings can achieve. This all-in-one zoom lens is ideal for travel and everyday shooting. It allows a photographer to switch from wide-angle to ultra-telephoto without changing lenses, making it faster and easier to capture a much wider range of subjects including travel scenes, wildlife, action sports, landscapes, cityscapes, portraits and food.
    Excellent image quality across the entire zoom range, from wide-angle to ultra-telephoto and macro
    The optical construction of the B028 consists of 16 lens elements in 11 groups. The use of specialized glass elements such as LD (Low Dispersion) and aspherical lens elements effectively minimizes wide-ranging aberrations, including chromatic aberrations and distortion, thereby assuring outstanding image quality. Optimum power distribution among the individual lens element groups achieves both the optical performance and the compact size necessary for an ultra-telephoto all-in-one zoom lens that boasts 400mm focal length. Also, it enables tele-macro photography with a maximum magnification ratio of 1:2.9.
    Lightweight and compact design exhibits Tamron’s basic philosophy for all-in-one zoom lenses
    Despite being an all-in-one zoom lens that achieves 400mm ultra-telephoto, Model B028 is light and compact with a total length of 4.8in. and a weight of 24.9oz.4 A new lens barrel design utilizing three-step extensions was developed to enable the necessary elongation to produce a 22.2x zoom ratio. Compared to the conventional approach, the division into a larger number of cams ensures comfortable operation and stability while zooming. Tamron’s philosophy for all-in-one zoom lenses is to allow each photographer to casually capture everyday photos with a lens of a practical size, and Model B028 fulfills this philosophy.
    HLD motor provides high-precision AF and enables compact lens construction
    The AF drive system for Model B028 uses Tamron’s exclusive HLD (High/Low torque modulated Drive) motor. The power-saving HLD motor produces outstanding driving torque, and adjusts motor rotation from low to high speed to enable accurate and quiet focusing. The HLD motor takes up less space thanks to its small size and circular arc shape that allows the size of the lens to be reduced.
    Equipped with the Vibration Compensation system necessary for ultra-telephotography at 400mm
    Despite its compact size, Model B028 is equipped with Tamron’s proprietary VC (Vibration Compensation) system, which effectively curbs camera shake under low light conditions (such as a dimly lit room or at dusk) and while taking ultra-telephoto pictures. This greatly expands opportunities for casual handheld shooting. The jitter-free stability of the viewfinder image allows for easier framing and enables the photographer to compose the subject quickly and comfortably.
    Electromagnetic diaphragm system now used also for Nikon-mount lenses
    The electromagnetic diaphragm system, which has been a standard feature for Canon-mount lenses, is now employed in Nikon-mount lenses5. More precise diaphragm and aperture control is possible because the diaphragm blades are driven and controlled by a motor through electronic pulse signals.
    User-friendly features for everyday comfortable use
    With an eye toward active outdoor photography, Model B028 features Moisture-Resistant Construction to ensure worry-free shooting as well as confidence while shooting under adverse weather conditions. Also, the Zoom Lock mechanism prevents undesired movement of the lens barrel under its own weight when the camera is angled downward while walking.
    Compatible with TAP-in ConsoleTM, an optional accessory product
    The optional TAP-in Console provides a USB connection to a personal computer, enabling the user to easily update the lens’s firmware as well as to customize features, including fine adjustments to the AF and VC.
    External design placing importance on functionality and ease of use
    While inheriting the design that makes use of many organic curves and the delicately polished form down to fine details that characterize the SP lens series, the new Model B028 comes with a highly sophisticated design that also places a lot of importance on the lens’s functionality and ease of use, featuring an overall form that faithfully encompasses the internal structures within, a slim Luminous Gold brand ring and the switch shape design.
  • Focus drive
    650 x 428 - 38K
    800 x 525 - 88K
    707 x 533 - 49K
    710 x 530 - 48K
  • Wow. Grate lens for all purpose.
  • Review
    At 18mm center and edge sharpness are very good between f/4 and f/11, with some softness evident wide open at f/3.5. At f/16 and f/22 sharpness is beginning to drop off due to diffraction.
    At 400mm both center and edge sharpness are very good between f/11 and f/22. At f/32 and f/40 sharpness is beginning to drop off due to diffraction.
    http://www.photographyblog.com/reviews/tamron_18_400mm_f3_5_6_3_di_ii_vc_hld_review/
    800 x 601 - 80K
    800 x 534 - 86K
    650 x 454 - 42K
    650 x 458 - 33K
  • Review
    Judged subjectively, central sharpness ranged from acceptable to excellent across the zoom range, with confirmation coming via our Imatest tests. Photographers who don't require edge-to-edge sharpness at wide-to-medium apertures should have little to complain about in this respect.
    http://photoreview.com.au/reviews/lenses/aps-c/tamron-18-400mm-f-3.5-6.3-di-ii-vc-hld-lens-model-b028
    598 x 410 - 40K
