50-135mm T2.9 Cine Fujinon lens
    • F-No. - F2.75
    • T-No. - T2.9
    • Image size - 24.84mm × 13.97mm(φ28.5mm)
    • Minimum Object Distance - 1.2m (0.85m in macro)
    • Number of iris blades - 9
    • Filter diameter - 82mm
    • Front diameter - 85mm
    • Length - 206mm
    • Weight - 980g
    The Optical Devices Division of FUJIFILM has unveiled the MK Series of cinema lenses for E-mount cameras, which boast advanced optical performance, ultra-compact and lightweight design, as well as superb cost performance. The first in this series to be introduced, the FUJINON MK18-55mm T2.9, is a standard zoom with an 18-55mm focal length. It will be available in early March at a list price of $3,799. The entire “MK” series is designed with the ‘emerging’ cinematographer in mind, whether shooting a live event, online programming, documentary, corporate video, wedding, independent or short film production.
    The next in the series, the FUJINON MK50-135mm T2.9*1, will be available this summer. With a combined focal length range of 18mm-135mm in the Super 35mm format, together the first two “MK” lenses cover the most frequently used range utilized by emerging cinematographers. The series offers fast lenses with T2.9 speed across the entire zoom range, enabling a shallow depth-of-field.
    “The rapid growth in popularity of content produced by emerging cinematographers has expanded the use of cinema and digital photographic cameras,” said Tom Fletcher, Director of Sales, Optical Devices Division of FUJIFILM. “And the heightened need for programming has, in turn, boosted demand for high-performance cinema lenses, which are ideal to achieve a shallow depth-of-field and a beautiful bokeh. However, since they are typically large, heavy and expensive, those involved in online and other lower cost productions often opt for interchangeable lenses for digital cameras, which have been more affordable and mobile. The problem is that interchangeable lenses for digital cameras are designed primarily for shooting stills, and therefore prone to focus shift and optical axis shift while zooming.”
    The “MK” lenses are designed to maintain consistent color temperature with all FUJINON cinema lenses, which simplifies color grading2. The series also inherits the FUJINON cine lenses’ advanced edge-to-edge optical performance and low distortion3, while boasting compact and lightweight design as well as outstanding cost/performance. The MK18-55 and MK50-135mm weigh in at a light 980 grams/2.16 lbs with front diameters of 85mm and lengths of 206mm. The MK18-55mm’s minimum object distance (MOD) is .85 meters/2.78 feet, while the MK 50-135mm’s MOD is 1.2m/3.93 feet.
    “Many independent shooters use DSLR lenses, which aren’t designed for moving images. Still lenses breathe considerably, and they have no adjustable manual iris,” said Fletcher. “Our MK’s have a seamless manual iris, zero breathing, no ramping or zoom shift, and 200-degree focus rotation. They maintain focus completely throughout the zoom range while covering Super 35mm sensors.”
    In addition to their lightweight and compact build, the “MK” lenses are designed from the ground up with the operator in mind. Only one matte box and one filter size are needed between the lenses. Time-saving features include a macro function that allows for a broader range of close-up shooting, and gears for the three rings are positioned in the exact same place, which eliminates the need to re-position accessories when switching lenses.
    The lenses each contain a Flange Focal Distance adjustment function*4 to achieve optimal camera and lens matching. The short flange focal distance contributes to the lenses’ compact size and lightweight. Distances are listed in feet and meters.
    The iris supports seamless adjustment that is free of clicking. This enables precise exposure adjustment without any sound from clicking between T-stops.
    The lenses also feature three rings for manual and independent adjustment of focus, zoom, and iris (aperture), with the gear pitch*5 of 0.8M (module). The focus ring can rotate fully up to 200 degrees to facilitate precise focusing.
    The “MK” lenses are compatible with E-mount cameras with the Super 35mm/ APS-C sensor.
    X Mount versions of the MK lenses (with focal lengths of 18-55mm and 50-135mm) used in the FUJIFILM X Series line of digital cameras (with APS-C sensors) are being developed for launch by the end of this year. Information about the X Mount lenses will be provided as soon as more details are confirmed.
    735 x 449 - 36K
  • 9 Replies sorted by
  • Our NAB stuff
  • Release date PR
    FUJIFILM Corporation (President: Kenji Sukeno) will release the FUJINON MK50-135mm T2.9 (MK50-135mm) telephoto zoom cinema lens in July 2017. The MK50-135mm has a focal length of 50-135mm and can be combined with the FUJINON MK18-55mm T2.9 (MK18-55mm) standard zoom lens, that was released in March 2017, to form a kit that covers the most frequently-used focal lengths of 18mm to 135mm, accommodating a broader variety of conditions.
    The rapid growth in popularity of movies made by emerging cinematographers in recent years, including corporate and commercial movies on the internet and other venues, has increased the opportunities for shooting movies using cinema and regular digital cameras, and it boosts demand for high-performance cinema lenses that deliver high resolution and advanced scene-depicting capability. For filming such materials, interchangeable lenses for digital cameras are often used instead of cinema camera lenses as they are more affordable and mobile. However, these lenses are designed primarily for shooting still images, and therefore prone to problems such as focus shift and optical axis shift while zooming, and so on.
    In response, Fujifilm has developed the MK series of cinema lenses that resolve these issues while still offering advanced optical performance and an ultra-compact and lightweight design - all at an affordable price. The MK18-55mm that was launched in March this year has been popular among emerging cinematographers who praise it for its edge-to-edge sharpness and ease of handling thanks to its compact and lightweight design.
    The new MK50-135mm is a telephoto zoom lens that covers the focal length from 50mm to 135mm. It has the maximum T-stop value of 2.9 across the entire zoom range, enabling to shoot with a shallow depth-of-field with beautiful bokeh. The lens is compatible with E-mount cameras with the Super 35mm / APS-C sensor. It incorporates the benefits of short flange focal distance into optical design to the maximum extent to achieve advanced optical performance while maintaining a compact and lightweight design.
    The lens design is optimised for shooting movies, minimising focal and optical axis shift while zooming and lens breathing (change of angle of view during focusing) – negative traits that are typically observed in still lenses for digital cameras. The lens also features three rings to enable manual and independent adjustment of focus, zoom and iris (aperture), all with the gear pitch of 0.8M (module). The focus ring can rotate fully up to 200 degrees to facilitate precise one-handed focusing. These features make the lenses comfortable to operate.
    The MK50-135mm can be combined with the MK18-55mm to form a compact and lightweight kit that covers the most frequently-used focal lengths between 18mm and 135mm, accommodating a variety of subject matters including landscape, architecture and portraiture. They share the common front element diameter, filter thread and three-ring gear positions, allowing users to share the use of the same accessories such as matte box and filters. This eliminates the need to re-adjust accessory positions when changing between lenses, streamlining operations in frontline video production.
    The X Mount versions of MK lenses (with the focal lengths of 18-55mm and 50-135mm) for Fujifilm’s X Series of digital cameras (APS-C sensor) are currently under development, and due to be released by the end of this year.
    FUJINON lenses offered by Fujifilm have been used at movie / CM / TV production sites around the world for their advanced scene-depicting capability. Tapping into its optical design, high-precision processing and assembly technologies that have been nurtured over the years in the cutting-edge field of video production, Fujifilm will continue to expand its lens line-up to meet the diverse needs at the video production industry.
