35-100mm F2.8 II Panasonic 2017 lens
    PR
    LUMIX G X VARIO 35-100mm / F2.8 II / POWER O.I.S. (H-HSA35100)
    • Allows high-speed shutter release, and provides beautiful defocus effect in portrait or close-up shots.
    • Achieves handheld shooting without using a flash thanks to the F2.8 wide aperture and 5-axis Dual I.S.2. even in low-lit situations including indoors.
    • Splash/dust-proof and freeze-proof down to -10℃ with a rugged design for heavy field use.
    • Supports high quality video recording(as described above).
    • The lens system comprises 18 elements in 13 groups including 1 UED (Ultra Extra-Low Dispersion) lens and 2 ED (Extra-Low Dispersion) lenses.
    • Panasonic’s black box technology Nano Surface Coating is applied to minimize ghosts and flaring.
    • Max.240-fps sensor drive for high-speed, high-performance AF.
    • No front lens rotation/ length extension in zooming.
    The HSA35100 will be available in black for $1099.99 in March.
    631 x 416 - 44K
  • 2 Replies sorted by
  • Panasonic G X 35-100mm f/2.8 II ASPH Lens for G Series Cameras W/Free Acc Bundle, $997
    https://www.adorama.com/ipc35100na.html
