Say im shooting run and gun with a blackmagic camera in prores.
What is the fastest way to check white balance color temperature (without putting a grey card in front of subject)? Is there a meter that i could throw on a rig that would give me general readings to adjust white balance quickly? General accuracy is ok. thanks
I have a light meter. It reads the same as my camera and my phone.
What you mean under this?
As part of light meter performance is that good ones have spot and wide (half dome) metering.
@cls105 - you're talking about a color meter. I use the vectorscope on my atomos ninja to get me close color-wise, then tweak to taste.
http://ww.lu.mu/ This plugs into your iphone 5s
https://itunes.apple.com/gb/app/cine-meter-ii/id846918884?mt=8 And this is the software that goes with it. Cheapest way into color metering. By all accounts, pretty accurate. Does luminance readings as well.
The lumu looks like a great back up to having the real meters. I mean, when one is lighting and color balancing on a set, all those texts & phone calls coming in might get just annoying :-)
@DrDave - that reviews the older lumu version, which works with iPhone 4s. It's functionality is restricted to luminance readings. The lumu power functions as a color meter too, but will only work with iPhone 5 and above.
Hmmm no android version?
Using Light meter
Using old meter
