So I'm thinking about this setup since I've come across the JL preamp as a bargain. Yet I'm quite a beginner as it comes to sound.
The Juicedlink doesn't have headphones input. However, the Zoom H1 does. Can I monitor the sound via the Zoom then? And in which way will this be a reliable headphone output volume? Do I need special cables? Or ways to set the Juicedlink pre-amp?
Help will be appreciated
Matt
Why you can't monitor on H1? You can. Headphone volume depend on headphones also.
You can monitor through VU and headphones on Zoom H1.
@Vitaliy Kiselev Also with a pre-amp inbetween? How about headphones without volume control? The Juicedlink model doesn't have a volume indicator, so how would I be able to hear I'm on a sufficient volume?
@Cid What do you mean with VU? If you mean Volume indicator, this pre-amp model doesn't have one.
thanks for quick response by the way.
Yes, of course. You need to monitor final result. About levels - you'll need to look at H1 screen for level indicator.
Great, I'll try soon enough and will show it goes.
Just get the Tascam DR-60D, they're going ridiculously cheap, especially if you dig around second hand a little.
