Sony A7s II 4K low light beast topic
    • 12.4Mp FF sensor
    • 2.4Mp XGA OLED EVF
    • 5 axis sensor stab
    • Wi-Fi and NFC
    • XAVC S 4K: 3840 x 2160 (30p/100Mbps, 30p/60Mbps, 24p/100Mbps, 24p/60Mbps)
    • XAVC S 4K: 3840 x 2160 (25p/100Mbps, 25p/60Mbps)
    • XAVC S HD: 1920 x 1080 (60p/50Mbps, 30p/50Mbps, 24p/50Mbps, 120p/100Mbps, 120p/60Mbps)
    • XAVC S HD: 1920 x 1080 (50p/50Mbps, 25p/50Mbps, 100p/100Mbps, 100p/60Mbps)
    • Black level, Gamma (Movie, Still, Cine1-4, ITU709, ITU709 [800%], S-Log2, S-Log3), Black Gamma, Knee, Color Mode (Movie, Still, Cinema, Pro, ITU709 Matrix, White&Black, S-Gamut, S-Gamut3.Cine, S-Gamut3),
    • Audio Level Display, Audio Rec Level, Auto Slow Shutter, HDMI info. Display (On/Off selectable), Time Code/User Bit, Picture Profile, Creative Style, Picture Effect, Rec Control, Dual Video Rec, Marker Setting, PAL/NTSC Selector, Gamma Display Assist
    • 8bit HDMI only output
    • 126.9 x 95.7 x 60.3 mm
    • $2999 at http://www.bhphotovideo.com/c/product/1186034-REG/sony_ilce7sm2_b_alpha_a7sii_mirrorless_digital.html
    Samples
    589 x 384 - 33K
    695 x 456 - 32K
    636 x 761 - 65K
    800 x 570 - 56K
    800 x 873 - 77K
    800 x 443 - 41K
  • 232 Replies sorted by
  • Full PR
    Sony today announced the latest addition to its award winning series of compact, full-frame α7 cameras with the introduction of the α7S II. Offering ultra-high sensitivity and wide dynamic range across the entire ISO range and 5-axis image stabilisation for greater shooting control, the α7S II delivers stunning image quality for photographers who shoot in the most challenging light conditions. Be it the brightest of mornings or darkest of nights, the α7S II enables new levels of photographic expression at whatever shutter speed you wish to deploy. The α7SII also incorporates a host of pro-style movie functions including the ability to shoot 4K video with full pixel readout and no pixel binning in full-frame format, making it an extremely appealing proposition for photographers and videographers alike.
    The α7S II delivers an awe-inspiring sensitivity range of ISO 50-409600[i], thanks to the combination of its 35mm full-frame 12.2 megapixel[ii] image sensor and BIONZ X image processing engine. The sensor optimises the dynamic range across the entire ISO range and broadens the range of tonal gradation in bright environments and minimises noise in dark scenes meaning that it delivers impressive results even in the most extreme conditions. The upgraded image processing algorithm of BIONZ X maximises the sensor’s capabilities and improves depiction throughout the full sensitivity range with particular emphasis on the mid-to-high range. This means that the resulting stills and movies demonstrate extra-fine detail with minimal noise.
    Video Master
    The α7S II can record 4K[iii] movies internally in the XAVC S format[iv] meaning that content is wonderfully detailed. Because information from all pixels is utilised without line skipping or pixel binning, the camera can maximise the expanded power of the full-frame image sensor and produce 4K movies with higher image clarity and negligible moiré. Full pixel readout without pixel binning is also employed when shooting Full HD[v] movies which means that it collects information from approximately five times as many pixels that are required to generate Full HD[vi] and condenses the information to produce extremely high quality movies.
    In a first for the α7 series, the α7S IIcan record 120fps at 100Mbps[vii] with full pixel readout without pixel binning in full frame format which can be edited into wonderful 4x/5x slow motion footage[viii] in Full HD. The α7S II also has the ability to shoot 4x/5x slow motion footage internally which can be immediately reviewed on the camera screen.
    Video functionality has been further enhanced with new profiles; S-Gamut3.Cine/S-Log3 and S-Gamut3/S-Log3. These new profiles deliver wide dynamic range and colour correction is easier to perform. The α7S ll even offers impressive 14-stop latitude in the S-Log3 gamma setting. The camera also supports S-Gamut/S-Log2 which is very popular among cinematographers and videographers. Gamma Display Assist is a new function that allows users to monitor images or check focus when recording S-Log movies and the Zebra function has been improved for even greater control.
    5-Axis Image Stabilisation
    The new α7S II is equipped with the innovative 5-axis image stabilisation system that is proving extremely popular in the α7 II and α7R II cameras. The system corrects camera shake along five axes during shooting, including angular shake (pitch and yaw) which has the greatest impact on image quality and tends to occur with a telephoto lens, shift shake (X and Y axes) which becomes noticeable as magnification increases, and rotational shake (roll) that often affects night shooting or video recording.
    Autofocus accuracy
    The autofocus system on the α7S II has been upgraded and now offers 169 AF points for fast, precise focusing with greater accuracy.[ix] The power of the image sensor means that the absence of noise in images generated, enables the Fast Intelligent AF to detect contrast more easily and react speedily even in low-light situations (as low as EV-4), when it’s even tough to check with the naked eye. When shooting video, the AF performance is twice as fast as the predecessor model.[x]
    Electronic Viewfinder
    The XGA OLED Tru-Finder in the α7S II has been upgraded and offers the world’s highest viewfinder magnification[xi] of 0.78x (roughly 38.5 degrees in diagonal field of view) and shows clear images across the entire display area. The use of ZEISS T* Coating ensures sharp reduction of reflections on the viewfinder and unlike an optical viewfinder, the OLED Tru-Finder can be used to instantly show how exposure compensation, white balance and other selected settings are affecting the displayed image.
    User upgrades
    A number of enhancements have been made to the look and feel of the α7S II to make it more user friendly, reliable and intuitive. Its magnesium-alloy body is both light and highly robust and the grip and shutter buttons have been re-designed so that the camera feels more natural in the hand. For situations when you just want to blend into the background, silent shooting mode can be activated for 5fps continuous shooting[xii] and reliability has been enhanced with reduced-vibration shutter movement.[xiii] The lens mount has been further reinforced to ensure greater resilience, particularly when attaching third party lenses and users can now charge the camera via a USB power supply whilst the camera is in operation, thus extending battery life. For greater comfort and safety, Sony is also launching the LCS-EBF; a new premium leather body case for the α7S II which is also compatible with the α7R II and α7 II.
    The α7S II is also Wi-Fi® and NFC compatible and fully functional with Sony’s PlayMemories Mobile application available for Android™ and iOS™ platforms, as well as Sony’s growing range of PlayMemories Camera Apps, which add a range of fun creative capabilities to the camera. Learn more at www.sony.net/pmca.
    The new α7S II full-frame interchangeable lens digital camera from Sony will be available in Europe in November 2015, priced at approximately €3,400.
  • Incredible, except the price.
  • For what it does, the price seems right.
  • It will be interesting to test SGamut3.cine/SLog3 to LC-709 Type A LUT on this camera.
  • Well, it's not a complete 4k product if it doesn't have almost 60p.
    But for the rest, it's a monster. Hands down, it's over for all.
  • "users can now charge the camera via a USB power supply whilst the camera is in operation, thus extending battery life".
    Or Sony, you could have put a proper battery in the body in the first place. Panasonic managed it with the GH4. It isn't rocket science.
  • Yeah Sounds amazing!! But I will wait and see what the Rolling shutter is like along with the battery life...and heating!!!
  • But SLog3 and SGamut3? Finally! SLog2 is a PITA to grade.
  • Is the video in 8bit 420?
  • @monowav Internal, yep. HDMI out is 8 bit 422.
  • AlbertZ, I agree this should be the big headline feature for this camera!! But I fear its 8bit can't cope with the aggressive s log 3
  • 3400€ for 5fps, contrast AF, no touch screen, old 12MPx senzor????? WTF, Sony???
  • Sorry, can get the last part. Means in video mode iso start from 600?
  • @Renovatio
    It is not clear from the video. The problem with electronically-controlled producs is that Marketing tells you what the range of various settings are in isolation, without ever mentioning the cross-effects likes in "sure we can do 5.5 frames/sec" but then you discover that it can do this only with fixed ISO of 200 or without auto-focus...
    On needs to wait 3 months after general availability and read comments by early-adaptors to flesh out all the limitations before committing.
  • Good thing to understand that current generation of cameras is transitional, as real new 4K generation will feature 10bit HEVC or similar codec (legal encoder issues are severe now), all this at 50 and 60 fps. Top video oriented cameras will all feature raw recording (same as latest DJI).
    I expect prices on A7r II and A7s II to set record on falling in the industry in next 1,5 years.
  • I just ordered an A7sII.
    Now, what to do with that old obsolete A7s beast? Perhaps I will include a half dozen batteries and that old 24-70 lens I have only used twice and sell it on Graig's list.
  • @RRRoger
    One thing I want to see is how fast all the A7r II proponents in video related part of the spectrum (and this was for camera that overheat during any long video shooting!) will move to prizing A7s II only.
  • The S-Log work to ISO 3,200 with A7S, what ISO need A7SII?
  • 3200 for S-Log 2, 1600 for S-Log 3.
  • I dont understand. For record interior to that ISO you can need ND filter. And with the GH4?
  • 400 for V-Log.
  • Shame there's still a 30 min limit.
