Hi there. I have seen a Pentax K1000 + 50mm Pentax-M lens going cheap in my local store. I'm interested in the lens, but can't seem to find a Pentax-M to m4/3 adapter. Is it possible to adapt this lens for use on my GH4? Thanks in advance.
Ah - M designated lenses are apparently all K mount.
Yes. You´re right -> So just search for a Pentax-K to m4/3 adapter ^^. Or check out the RJ Lens Turbo - Which you can get here through Vitaliy. (Seems to be a quite nice focal reducer for it´s low price.)
You can get for example a Pentax K to M4/3 or you can also use the EF to M4/3 version for example. And use an additional Pentax K to EF adapter - So you can mount your 50mm Pentax-M. The EF version is more flexible - As you can adapt MANY other mounts to it (Nikon F, Olympus OM, Contax/Yashica, Pentax K, M42, Leica R and so on).
HTH ^^
