Without a doubt, http://www.personal-view.com/talks/discussion/334/gh1-75mbps-peak-reliability-setting-v2-update/p1 I've shot hundreds of sports event videos with this patch, all in 60 or 50p depending on where in the world the event is.
Well....I took this patch out for a spin on my revived GH1, and have extreme macroblocking in defocused areas. Smart-phone video macroblocking, that bad. Doesn't seem like the patch and my cam are able to play nice, even though Quicktime info is showing 75mbs on the clips. Glad others have had better luck with this over the years, but think it's time to shop for a 60p cam. Appreciate the suggestion in any case.
I take my GH1 to forest few weeks ago (after 2 years on shelf) and I got crashing after every few seconds even 2.8f and 50shutter can't use it in detail environment. This tread remind me to refresh hack on my old friend. Do you remember safe long recording settings (like cake for GH2) ? for 1080 25p use only
You probably need to read that thread to get the best results. I doubt your getting 75mbps on the clips, my average rate with sharp kit lenses, deep DOF and lots of motion and detail is 35-42mbps, 75 is the peak max. If you have little detail and mostly shallow DOF, the gh1 with any patch will fall back to 20-30mbps, even less in poor light. The gh1 is not the gh2 by any click of the clock.
Yeah, I found it odd that Quicktime info is reporting the patch's max as the clip's data rate. Another weird thing, I did not get a folder of .MTS files from my shoot, but rather a single AVCHD file that seems to have all the clips embedded? I don't remember this being the case. I certainly could have done something wrong here.
I just tested "lpavel 75 v2" in 25p - its not the best unfortunately. Good thing is its keep rolling forever with no crashing even with sharp lens, f6 shutter400 grass filming. However nitrate is quite low maybe even lower then stock ;). Does not even hold little adjust of WB in Pro. 2h15min detailed footage its only 7.18 gb. I will test 1080p 100mbs mention in the topic.
I use "reliable playback". It's lower sustained bitrate than peak reliability but imho the quality is great ....also in 720/60p. I use cinema tools to conform. Your file structure should look exactly the same. I'd guess something's wrong with your hack job. And even with reliable playback you need a fast class 10.
GH1's weak point is the data bottleneck of its SD card slot. I have managed to get the highest bitrates in the "Varigop" setting and wonderful image quality both for 50/60p and 24p.
Yet, the hacked GH1 is not really a stable camera. Try to make a shot of lavander by sunshine where all is in focus. Green colors + lots of details = GH1 freezes (with just any setting) after max 2min. I still love that camera and use it a lot. I don't encounter any problems by fast motions or tele shots.
Attached are a couple 1:1 crops off the card, showing the kind of compression artifacts I'm seeing. In motion the artifacts dance around horribly. I know this isnt the GH2-4, but I was sure the cam was capable of more. Is this to be expected in SH mode with the best 60p patch? Thanks for all the suggestions, I'll try Reliable Playback and Varigop next.
