Single-Handed 3-axis Gimbal Systems
| Beholder MS1 BHPP | ProGlide | Nebula 4000 Lite | The Pilotfly H1+ | CAME-Single | |
| System | 8-bit | 8-bit | 8-bit | 32 Bit Dual IMUs | 32 Bit Dual IMUs + Motors with Encoders |
| Changeable battery | Yes | Yes | No | No | Yes |
| Joystick | Two-Axis | Single-Axis | Two-Axis | ||
| Bluetooth | Yes | Yes | No | ||
| 3 way Balancing Adjustments | No | No | Yes | Yes | Yes |
| Inverted Mode | No | Yes | No | ||
| Weight | 778g | 700g | 800g | 870g | 1.2kg |
| Max payload | 0.85kg | 0.85kg | 1kg | 1.2kg | 1kg |
| Travel Case | soft case | soft case | hard case | ||
| Price | $500 | $500 | $700 | $800 | $1000 |
