single-hand-gimbals
Single-Handed 3-axis Gimbal Systems
Newer models, 2016 year models
Zhiyun Crane Beholder EC1 Beholder DS1 Pilotfly H2 Came-TV Optimus
System 32-bit 32-bit 32-bit 32-Bit 32 Bit + Encoders
Changeable battery Yes Yes Yes Yes Yes
Joystick Two-Axis Two-Axis Two-Axis Two-Axis Two-Axis
Bluetooth No Yes Yes Yes No
Balance Adjustment Yes Yes Yes Yes Yes
Inverted Mode No No No Yes No
Weight 950g 997g 997g 1.2kg 1.2kg
Max payload 1.2kg 2.23kg 2kg 2.2kg 1.1kg
Case Soft Case - hard case soft case hard case
Price $600 $900 $700 $1049 $1380
Older gimbals, 2015 mostly
Beholder MS1 BHPP ProGlide Nebula 4000 Lite The Pilotfly H1+ CAME-Single
img_0636.jpg beholder_b_1.jpg 25464337-origpic-3990df.jpg pilotfly-h1-handheld-3axis-stabilizer-for-mirrorless-camera-.jpg came-single-preorder.jpg
System 8-bit 8-bit 8-bit 32 Bit Dual IMUs 32 Bit Dual IMUs
+ Motors with Encoders
Changeable battery Yes Yes No No Yes
Joystick Two-Axis - Single-Axis Two-Axis
Bluetooth No Yes Yes No
3 way Balancing Adjustments No No Yes Yes Yes
Weight 778g 700g 800g 870g 1.2kg
Max payload 0.85kg 0.85kg 1kg 1.2kg 1kg
Travel Case soft case - hard case soft case hard case
Price $480 $500 $700 $800 $1000
single-hand-gimbals.txt · Last modified: 2016/08/13 20:36 by vitaliy_kiselev
