Beginners: Basic hacks questions
  • 1012 Replies sorted by
  • There are HBR mode hacks going up to 60 Mbps or so, and 24p hacks up to 140 Mbps. The quality will depend on a lot of factors, including the bit rate, what you are shooting, and how the settings are constructed.
    There are settings available from several guys on personal-view. One of them will meet your needs. Look around and try some different things. http://personal-view.com/talks/categories/hacks
  • Thx, balazer! This mean that with original firmware 1.1 - 1080p/24fps (21Mpbs) = 1080p/30fps(24Mpbs) in quality terms? And not possible set bitrate >24Mpbs in Ptools for 1080p/30fps?
    Ok. A 1080p/30fps remain as is.
    Pls, post INI with:
    1. 720p/50fps c B-Frames with bitrate 28-34Mpbs with the best quality.
    2. 1080p/24fps with the best possible quality with two options - 24Mbps (24L) and 32Mpbs (24H)
    I tried, but have small skill for tunning ptools settings. :( Help me with ideal INI for Transcend SHDC Class-10!
  • HBR 25p and 30p configure the sensor to output a high quality progressive image, just the same as 24p mode does. But HBR uses the same interlaced encoding that 25i and 30i use, and that interlaced encoding is not able to support the same high hacked bit rates that 24p can. So HBR can look quite good, but 24p can look better, especially on demanding scenes. (high detail plus motion, or high noise)
  • Can anyone suggest any of the experienced testers - Panasonic has done a really high quality (native) 1080p/25 (30)fps in the original 1.1 firmware, or it a post-processing from hardware 50i/60i mode? Which mode - 1080p/24p or 1080p/30p actually gives more quality for frame at the same bitrate for each frame? In other words - is a 1024p/30fps picture quality equal 1024p/24p (for each frame), except for the frame rate?
    I only have cards class-10 (Transcend, real speed - 16Mbyte to write and 16Mbyte to read). I almost do not do postproductions, but only store the original recorded video, as it is. Can you recommend the best settings to PTools? I would like to have the following stable options with Transcend Class 10 card: 1. 720p/50fps c B-Frames with bitrate 28-34Mpbs with the best quality. 2. 1080p/24fps with the best possible quality with two options - 24Mbps (24L) and 32Mpbs (24H) 3. 1080p/25fps with the best possible quality with bitrate 28-34Mpbs (HBR) 4. 1080p/30fps = 1080p/24fps on the quality of each frame, but just with more frame rate and bit rate - (HBR) 28-34Mpbs.
    Thank you in advance of experienced testers who respond to my request and post INI file meets my request!
    p.s.Sorry for the my awful English.
    p.s.s. 1080p/50(60)fps is unreal with 1.1 hack?
  • Just got my GH2 running Sedna. Thanks to everyone who has posted in this thread :)
  • ok, thx.
    I guess I just wasn't too sure overall exactly what the hacks changed, but I think I've got a grip on it now... basically just changing the bitrate and type of frames, etc within the established codec for each of the various record modes (hbr, etc). As I think through the implications of that, it answers a few other questions I've had.
    Will run a test later to see if my output is matching what I think it should now be for sanity 5. Will also do some more spanning tests before I commit to it for my shoot since there were spanning warnings. Seems to be doing fine on hbr with my extreme pro 95/64 card, though.
  • Whether hacked or just running stock firmware, you need to be in creative movie mode and select HBR to get 1080p/30.
  • ah. good point.
    Sanity seems to be spanning just fine for me, but a bit confused about something. Rec Mode menu only gives motion jpeg, avchd 720p and avchd 1080i as options.
    Been running through all the menus, and I'm just not sure how to be sure I'm running a proper 1080p 30fps since the menu settings don't really match what I'm reading online in terms of what the patch can do.
    That's in M mode anyway. Do I have to be in movie mode for the hack settings to be applicable? Just set to HBR and know that HBR is now 1080p 30fps since the firmware is changed?
  • @gregsage
    I always use the red button. I don't want the camera to refocus when I start a video. If you use the shutter button it will do that. If you use the red button it will not.
  • OK, got Sanity 5 loaded. Will test today to see about spanning on 95 mbps 64GB card. If not, I'll try the no adverse, and test it's spanning.
    I've seen a few comments here and there about people saying they never record video by pressing the red button, but not quite clear as to whether it's just preference or if there's a reason having to do with hacks or otherwise. Anyone know why I should or should not do it that way?
  • Greetings, I’m about to make a short film with the Panasonic GH2. I would like to know wich is the best hack up to date. I'm working with: SeaQuake - 24H - Sandisk 64GB Extreme Pro SDXC 95MB/s. ¿Is It there a higher hack version or am I good to go? Thanks
  • Is there anyway to review 60p in camera? And is it better to shoot in mpjeg or avchd?
  • Well, I was thinking Sanity 5, except for all the warnings about it not spanning in HBR.
    I've got a 95mbps 64GB card, though, so not sure if that makes a difference.
    Looking into NAE... Taking up a lot of people's time on this shoot, so trying to make sure no snafus waste that time.
  • Simple question I guess anyway to find out what hack I have on my GH2? Did the hack back in December I believe and don't remember which one it was.
  • @gregsage, if you don't care about sound and you want 30fps, try VMM 80% mode. It is 30fps played back at 24fps, you can easily speed it up by 25% to get back to 30fps in AE in post. I found it to be identical in quality with 24H (aka 1080p/24) in one test I did. In theory I think 24p should still do better but VMM 80% is your best 30 fps option. Try Sanity 4.1 or Sanity 5 or No Adverse Affects for good all around hacks. I started with those to get used to my camera. Then experiment with another patch if you find a particular need.
  • ok, thx
    I had watched the videos before... really just unclear about exactly what was being changed by the patches... and whether they're still all same encoding, true progressive, etc. There seems to be some conflicting info out there about the progressive scan part anyway.
    OK, so looks like I just need to settle on what sort of stability/bitrate compromise I'm comfortable with (sanity, no adverse, flowmotion, etc)
    Since I don't care about audio, but do care quite a bit about color info for greenscreening, am still a bit unsure as to whether a particular hack might have it's bitrate geared a bit more toward my needs than another.
    Rest of project (titling, backgrounds, 3d animations, intro, outro, etc) is already composited in 1080p 30fps, so I might as well get the footage shot that way.
  • @gregsage, I'm just getting started with this camera too and the manual isn't laid out the clearest. Add all the jargon of the settings (aka hacks) and it is a lot to digest in the beginning. But, keep reading and it starts to come into focus.
    Regarding your questions: "Basically, just wondering if there's a specific stable hack that not only makes sure it's true progressive, but makes the post process easier in general by outputting a format that's easy to import and work with in AE. For instance, is AVCHD really what I want in this scenario, or something else?"
    Someone will correct me if I'm wrong, but I don't think any of these settings/hacks changes the record modes (24 Cinema, Variable Movie Mode, HBR, SH, etc.) of the camera in terms of output fps rate or progressive/interlaced output, nor do they change output file formats. They only optimize the way the AVCHD codec that's built into the camera encodes the raw video by improving the tables it uses and bit rate settings.
    @Vitaliy_Kiselev 's tool has allowed removing some limits that were in the stock firmware such as ISO limited to 3200, allowing an NTSC/PAL switch, and enabling more languages but I believe all of these things were in the original firmware but locked out or set as toggles and ptool has allowed enabling them.
    The are switching bits around within the existing firmware in places they can improve the camera but I don't think they can write brand new software and compile that into a firmware the camera can use. It's amazing what they're able to do by splicing parameters into the stock firmware.
  • @gregsage
    Watch these two videos. Try clicking on the watch on youtube button to see the descriptions with all of the links.
    The short answer is that version 1.1 firmware enables 1080p @ 30 FPS with the HBR mode. If your editing software treats it as true progressive 1080p @ 30 FPS then it won't need any further processing.
    Try the "No adverse Affects" settings as a perfectly stable place to start.
    Version 1.1 changes
  • Well, I've read the manual, and quite a few posts here and elsewhere, but it's quite a lot of information, and though the answers may well be out there, they can still get lost at times... for me anyway.
    I've read that the GH2 can't really do 1080 30p... that it's always 1080i, but then can be fixed to be 1080p in post.... then I've read that it CAN do 1080p at 30fps with the new firmware... then I've read that it still isn't true progressive, and still needs to be fixed in post. It's hard to tell sometimes whether the posts and responses are accurate or outdated.
    I don't know much about the compression codecs... just enough to understand that I'd prefer something that doesn't need to be converted/decoded in order to be imported and edited. I know how to use AE, but I've never used the various compression codecs before.
    Also, doing greenscreen work, so wanting to make sure that of all the things that could be squashed in the name of bitrate, that color info is the least harmed.
  • @jvalal Balazer is right about those being good place to go for the answers to your questions. But I'll answer this last one before you get started. :) The short answer is, I already told you how to do it. But in case it was unclear, I'll try explaining it a different way.
    All modes (HBR, Cinema, and Variable Movie Mode) shoot 1080P, except for "Manual" (the one on the far left).
    Here are the ones you can select in manual (at least the ones that shoot in AVCHD).
    • FSH: 1920x1080, 50 fields, not frames (PAL) or 60 fields (NTSC), higher bitrate.
    • FH: 1920x1080, 50 fields, not frames (PAL) or 60 fields (NTSC), lower bitrate.
    • SH: 1280x720, 50 fps (PAL) or 60 fsp (NTSC), higher bitrate.
    • H: 1280x720, 50 fps (PAL) or 60 fsp (NTSC), lower bitrate.
    So basically, SH and H mode are the only modes that shoot 1280X720. You can select them in "Video M" mode or you can hit the circle (like you were originally doing before we started talking about all of this).
    Anyway, best of luck with the manual and GH2-usage. I think you'll find the answer to most of the rest of your early questions there, but feel free to ask more later once you get past what those can answer for you.
  • These aren't hidden features. They're well documented in your GH2 manual. Also, read the FAQs. http://www.personal-view.com/faqs/gh2-usage/gh2-usage
  • @thepalalias ok, but how do I get the settings in my cam to 1080p vs. 720? Assuming this is another simple setting I'm overlooking.
  • @jrd Thanks I played around with my GH2 a little and im pretty sure I got the hang of things now! :D
  • @jvalal The posts discuss all the modes those settings shoot. All the Driftwood settings can shoot 1080p at 24fps well - there are no exceptions to that so far. In the descriptions he also talks about how the settings are configured for other modes - that is what you were reading.
    The descriptions can get very technical - don`t spend too much effort trying to understand them until you learn more about what all the terms mean. In the Driftwood thread, I mentioned some of the differences between them (in the thread we started out in).
    Mysteron and Sedna are the best options if your main concern is image quality with an intra setting, given your card.
  • @thepalalias I get confused on the Driftwood posts. For ex. Orion Darkmatter patch states"...Details: Featuring the new 'Dark Matter' matrix set (three version variations) based on current Orion Matrix with hi/lo freq adjustments. Plus 720p on 9/6 GOP..."
    Does this mean it only shoots 720P? Looking at other patches they also say 720P, yet I thought I was capturing at 1080p? Confused.
