                  Nice rig, @ed_lee83. I too, am very interested in the type of view finders you mention, designed to allow you to view with both eyes (even with glasses on). I have recently read about the "magfinder" in the British "what digital camera" magazine. They tested it against the more conventional (one eyed) viewers & where quite impressed with it.
I can,t find the review online (i saw the printed copy). You can see the product at http://www.pinknoise-systems.co.uk/magfinder-p-614.html.
Where did you find yours?
@dark_fibre I bought mine retail in Hong Kong for a slightly lower price than that. It was called Loupe Master. I believe Jag35 has the same OEM product. I wouldn't say it's more "conventional" but great to use if u wear glasses. But I find that it easily fogs up from breathing when you have the shade attached. As such, i cut into the shade tO give my nose a little room and for my breath tO escape.
@ed_lee83.Thanks for that. I have just bought some nice underwater (skin diving) goggles from a specialist dive shop, they recommend an anti-fogging fluid. If you keep having issues something similar might be worth a try.
Could it be possible to hack Sony NEX series including 5n ? I see too much work in other cameras running and good results obtained.
Hi everybody...
I was doing some research to find the 5n video crop factor but i did not find...
I know the sensor is 1.5x crop factor for photos (from sony website) but i do not know if the camera add some adittional crop when shotting video (no information about).
I know the sony NEX VG20 camcorder is 1.5x crop for photo and 1.8x crop for video. In VG20 the 18-200mm lens is 27-300mm in photo mode and 32.4-360mm in video mode (35mm equivalent). (from sony website).
I just would like to know if someone can confirm or test the photo vs video mode in 5n to find if there is difference in what the camera can frame with the same lens in both modes.
Many thanks.
@apefos 5n is same for both video & photo and to me is around 1.5x ( keep also in mind of 4.3 aspect ratio for photo and 16.9 for video) I have a GH2 also (GH2 is 1.8 crop no?) and crop is more on GH2 than it is on 5n using same lens. As far as I knew same applies to VG20 as I thought it is essentially the same as a 5n just in a different body.
thank you for the reply. so it seems the 5n just change for 16:9 for video without any aditional croping. if so, it will be great because it will have the smalest crop factor from a low budget camera for video. I would love to see the same lens in gh2 and in 5n in a comparison video on vimeo... thanks
Tempted to get this body just for 60p 1080 for slowmo shots, sure it has got faults like can't record over 30 minutes before it over heats but for a $500 camera that can slowmo at 2.5x slower when slowed to 24p.. not a bad deal. besides who is going to record 20 to 30 minutes of slowmo footage in one shot.
who is gona shoot more than 20 to 30 minutes in a single shoot in a narrative work?
the 16mm k3 camera just shoot 30 seconds in each winding... and it was and is used to do narratives...
Alfred Hitchcock did a movie called ROPE all done with long shots of 10 minutes maximum: Hitchcock shot for periods lasting up to ten minutes (the length of a film camera magazine)
There is a solution for overheating developed using ram memory heatsinks:
Some heatsinks links
http://www.maplin.co.uk/ram-chip-heat-sinks-98850
http://www.ebay.co.uk/itm/Heat-Sink-SD-RAM-DDR-DDR2-DDR3-Memory-MC-200-Copper-/170780291147
                  Dang you apefos, your going to make me spend more $$$ now :)
@apefos I will do a crop comparison for you when I get a bit of free time.
As for the heatsinks...where did you find that??? Does it work?
Well, I did not test the heatsink myself. You can search "memory heatsink" on ebay and you will find lots of cheap options. I read somewhere the copper ones are better. Some of them come with an adesive to ease glue on nex-5n.
A crop comparison between 5n photo and video mode with same lens, same focal lenght would be great. (remember to use both 3:2 and 16:9 photo mode when doing that).
thanks
@apefos Oops ive literally just uploaded a video with the difference between the GH2 and 5N crop in video 16.9 but not photo. Will do a quicky 5n photo/video comparison later.
Quicker to demonstrate with photograb from video.
Lens was 24mm
As you can see from the left/right of image there's no crop. only the top and bottom are cut off for 16.9.
