Capitalism: RedHat wants money, will stop supporting and development of CentOS
  • The future of the CentOS Project is CentOS Stream, and over the next year we’ll be shifting focus from CentOS Linux, the rebuild of Red Hat Enterprise Linux (RHEL), to CentOS Stream, which tracks just ahead of a current RHEL release. CentOS Linux 8, as a rebuild of RHEL 8, will end at the end of 2021. CentOS Stream continues after that date, serving as the upstream (development) branch of Red Hat Enterprise Linux.
    Meanwhile, we understand many of you are deeply invested in CentOS Linux 7, and we’ll continue to produce that version through the remainder of the RHEL 7 life cycle.
    CentOS Stream will also be the centerpiece of a major shift in collaboration among the CentOS Special Interest Groups (SIGs). This ensures SIGs are developing and testing against what becomes the next version of RHEL. This also provides SIGs a clear single goal, rather than having to build and test for two releases. It gives the CentOS contributor community a great deal of influence in the future of RHEL. And it removes confusion around what “CentOS” means in the Linux distribution ecosystem.
    When CentOS Linux 8 (the rebuild of RHEL8) ends, your best option will be to migrate to CentOS Stream 8, which is a small delta from CentOS Linux 8, and has regular updates like traditional CentOS Linux releases. If you are using CentOS Linux 8 in a production environment, and are concerned that CentOS Stream will not meet your needs, we encourage you to contact Red Hat about options.
    They now want to offer you unstable alpha version of their RHEL software so you will be tester under the name of CentOS Stream, meaning that it is fully unsuitable for uses where people use present CentOS.
  • 2 Replies sorted by
  • For people who do not understand.
    It will have staggering impact, especially for hosting companies, small and medium business. As CentOS is used on 80-90% of their servers now.
    RedHat also even broke the promise to support CentOS until 2029 to artificially create crisis right at 2021.
    CentOS Stream name also suggest that we'll see monthly fees announcement very soon.
