@LongJohnSilver or Anyone--
In 6K anamorphic mode, can one select 23.976 (23.98) or is one limited to 24.00 fps? Specifically interested in the 6K option.
TIA.
Also, anyone using the Siui anamorhic lenses interested in your opinion. Tx.
Sorry I don't even know how to set 6k.
tx anyway!
@DrDave You can select 23.976 and 29.97 in the 59.94hz mode.
There are 3 system frequencies 24.0, 50, 59.94. Each frequency has different base frame rates.
Guys, how to get back to where you stopped using GH5 menu? I can bet there was an option "menu resume" and I can not find it anymore...
@LongJohnSilver - were you using one of varibale frame rates? As in this case AF/AE Lock does not work properly. At least on my copy of GH5...
No. I use 25/50p.
