Nvidia GPUs design
  • GTX 1030, ultra budget card
    GP108-300-A1 chip, SMMs - 3, 64bit bus, 48Gb/s bandwidth, 942 GFlops
    GTX 1050 / 1050 Ti, budget cards
    GP107-300(400)-A1, SMMs - 5(6), 128bit bus, 112Gb/s bandwidth, 1733(1981) GFlops
    GeForce GTX 1060 3GB/6GB, medium card
    GP106-300(400)-A1, SMMs - 9(10), 192bit bus, 192Gb/s bandwidth, 3470 (3855 ) GFlops
    GeForce GTX 1070 / GTX 1080, advanced cards
    GP104-200(400)-A1, SMMs - 15(20), 256bit bus, 256 (320)Gb/s bandwidth, 5783 (8228 ) GFlops
    GeForce GTX 1080 Ti, top cards
    GP102-350SMMs - 28, 352bit bus, 484 Gb/s bandwidth, 10609 GFlops
    You can see extreme savings on design, as all cards consist from literally same blocks, just different number of them.
  • 12 Replies sorted by
  • Interesting view on prices if you just look how much they charge per SMM block
    Two dips are due to cards with low memory amounts.
    800 x 417 - 90K
    Chart for Russia (got close to minimum prices).
    800 x 404 - 82K
  • I've compared GTX 1060 and GTX 1080 only.
    • H264, GTX 1080 encodes 70% faster than GTX 1060
    • HEVC, GTX 1080 encodes 140% faster than GTX 1060
    Interesting discovery - actually GTX 1080 have TWO encoder blocks.
    Also note that outside Quadro they block more than 2 streams.
    800 x 195 - 25K
  • When looking at benchmarks 1070 & 1080 are the two GPU's that are high performance. With the 1070 being the best $ per CUDA core. I think that the 1080's memory bandwidth is the limiting factor.
  • With the 1070 being the best $ per CUDA core. I think that the 1080's memory bandwidth is the limiting factor.
    It is not true, see charts with dollar per SMM. Best are 1060 cards for US.
    Also made for you memory bandwidth per SMM chart
    800 x 413 - 99K
  • I was looking more at these sort of benchmarks. A 980ti is much faster than a 1060. However a 1070 is basically on par with a 980ti yet uses less power.
    http://www.phoronix.com/scan.php?page=article&item=14way-nvidia-madmax&num=2
  • Nvidia GP106 GPU in Tesla cars computer
    698 x 720 - 109K
    I see zero reason to get 900 series cards now. Until may be if you get some amazing deal on top ones and use Resolve.
    Simplest thing is to just get 1080 Ti and go work if you use raw/ProRes and heavy grading. Instead of spending time.
    If just editing weddings and similar stuff, 1050 Ti /1060 6GB is enough for years ahead.
  • Yup. 1080Ti, however I also have my eyes on Vega. I'm thinking of a few 1080Ti's for rendering- or Vega's.
    Will reassess when the star falls!
  • Nvidia GPU plans for 2018
    542 x 452 - 29K
  • GV100 architecture (Volta)
    Single SMM close
    800 x 450 - 110K
    641 x 843 - 187K
  • Nvidia encoding
    And decoding features
    Note for high bitrates it is almost no reason to use software encoders
    800 x 316 - 47K
    800 x 297 - 40K
    800 x 290 - 32K
    800 x 290 - 32K
