Info
I'd go a step further and say "better than Apple and cheaper." Macbook Airs still have 720p screens, last time I checked, and have no discrete GPU option. I'm definitely interested in the 13" Mi Air when it becomes available in the US.
I added more info about configs.
Will be available from August 2nd, so soon.
Official page - http://www.mi.com/mibookair/
This seems to have better specs and is much cheaper but not as light.
http://www.newegg.com/Product/Product.aspx?Item=N82E16834234175&nm_mc=KNC-GoogleAdwords-PC&cm_mmc=KNC-GoogleAdwords-PC--pla--Notebooks-_-N82E16834234175&gclid=CKeZpOurlM4CFQNZhgodoqwJHQ&gclsrc=aw.ds
It is different product with DVD drive and such.
Fully true. Just remember that most people either never resell notebook or do it many years after buying.
Progress stalled, so such integrated machines will be actual years ahead.
If it will be popular and drivers will be working, well it can be done.
The 13" model has an i5. Performance delta between i5 and i7 for most purposes is not substantial.
not interesting without normal cpu (i7 mq or hq)
You literally can not make such notebook properly with 4 core HQ processor due to necessary cooling, unless you want to be constantly present on turbojet takeoff event provided by cooler :-).
If you think a little you understand that this statement make little sense. i5 and i7 are for long time marketing terms if you get notebook chips. You can have low power 2 core i7 CPU, and at the same time you have powerful but hot HQ true 4 core chips.
Better presentation slides for 13.3"
Notebooks after arrival will be available at
Teardown
Thunderbolt 3 for fast data transfer would make these a no brainer for me. oh well... will wait for Mi Air 2
As far as I can see ports are USB 3.1, as for thunderbird it makes sense only if you have two fastest SSD drives and transfer really big amount of info. Just note - all this build in SSD drives won't survive such usage for long.
Notebooks in stock and available at
Nice, but until it's a Hackintosh it is not comparable. Windows is a nightmare. Also the bezel is not uniform width (thicker on top and bottom than sides), which seems very un-Apple.
Windows is a tool :-) As for bezel - no one cares.
Xiaomi Mi Notebook Air Hackintosh (German)
Conclusion: MacOS 10.12 Sierra on Xiaomi Mi Notebook Air 12.5
The installation of macOS 10.12 Sierra on the Xiaomi Mi Notebook Air 12.5 works, but essential functions such as WLAN and trackpad are not available or only rudimentarily available. Also, the standby mode does not work. So you have to use a USB WLAN stick and a mouse to be able to work with the Xiaomi notebook under macOS halfway sensibly.
@jleo my understanding from TonyMac was that in most cases Hackintosh laptops need a USB WLAN dongle (I think they can be small). There are other compromises with them too, as in you can't take advantage of a discrete GPU (due to optimus ) but, I'm not a windows expert. The trackpad is a different story. Maybe look this thing up on TonyMac, they will know for sure.
