Hello. Could anybody say is g6 showing peaking via wifi? Thanks.
Yes, focus pointing works on both picture and in video mode. I still like a fool, say that the video quality of the G6 is better than my old hacked GH2. I don't care about the people who just have to say that all things have to to with bit rate. There are more to it! Buy It and try yourself.
@calleb Stick to your guns. Of course guys here with hacked GH2s are invested in believing that the stock $600 G6 can't shoot better looking video. If your eyes tell you you're getting better looking footage, you are. And you're absolutely correct, there is much more to this than just bitrate.
I can't wait to pick up a G6 and test it for myself. I'd love a GH2 replacement that's cheaper, smaller, lighter, and shoots better video at 1/4 the bitrate I'm shooting currently. If the G6 is that camera, it should be cause for celebration, not knee-jerk dismissal.
ok guys so check this and tell me pls ....did g6 will be better for video than gh2 ?
First handling impressions compared to GH2:
Cons: plastic fantastic body, feels very brittle. Control wheels and buttons much cheaper quality, especially shutter button and rear wheel. Peaking doesn't show up when you need it, only when stuff is obviously in focus. My Sony RX100 does a much better job at peaking. Even if the LCD is higher rez, I can tell focus easier on the GH2 thanks to the moire-ish pattern you get. EVF, same thing: GH2 is much sharper.
Pros: 3.5 mic jack! Rocker is well positioned and operates silently when changing exposure comp (to bad it isn't stepless) 50, 25, 24 1080p. Better color profile adjustments. Seemingly better ISO performance and much less banding.
I'm not overly positive yet. Lets see after a week!
Agree, It's more plastic than the GH2. I would compare it to Nikon D5200. But you really have consider the price tag. This is not a 1300 dollar metallic weather sealed GH3 for professionals. Focus pointing has to be engaged on the touch screen and works both in camera video mode and on wifi mode.
Also prefer LCD EVF to OLED. My OLY E-M5 EVF for example is really bad. But it's better in dark environments.
The blacks are black. No banding like with my GH2 and it's sharp.
I hope you'll get more positive. It took me a week but I'm hooked.
Post-purchase rationalization and self-deception go hand in hand ;) I own a G6 and honestly would very much like for it to match a hacked GH2 in video compression quality. Unfortunately it does not. Here is a short clip of a cityscape, original MP4 file from stock G6 (1080p50):
https://dl.dropboxusercontent.com/u/16587899/for_pv/P1340770.MP4
A still frame from it, in TIF format so there would be no further compression to ruin comparison: https://dl.dropboxusercontent.com/u/16587899/for_pv/P1340770_mp4_frame.tif
And for reference, a JPG of what G6 actually "sees" and what would be close to results of high video bitrate settings. All exposure, ISO, WB etc. settings are same as in video version, but image is resized to 1920x1080 from original 12mpix JPG and saved as TIF to avoid further compression: https://dl.dropboxusercontent.com/u/16587899/for_pv/P1340769_JPEG_low_still_resized_to_1080.tif
…and the original unresized JPG. You don't need it for comparison, but here it is if you want it for some reason: https://dl.dropboxusercontent.com/u/16587899/for_pv/P1340769.JPG
Look at buildings and fine details in the clip and frame stills. Look at roofs of buildings. On your computer, flick between TIFs of that MP4 frame and the JPG frame to see the difference clearly.
This is a kind of image that stock G6 can't compress well in video. There are many fine, moving details, the light is low, there are gradients on surfaces, heat in the air is warping the details and lowering contrast. A challenge for any camera that uses high compression ratio codec.
As I don't have a GH2 anymore, can't give you exact comparison of how best video compression settings on it can render view like this. But with 90+Mbps bitrates the GH2 would render that view much more faithfully, and more so with custom matrices you find in some settings here on PV. It'd be closer to that resized JPG than the MP4 frame. This I know after 2.5 years of owning a GH2 and using it both stock and hacked.
I'll save you the rant of how I generally feel about manufacturers doing this "we sell you good hardware, but cripple the software" thing. There would be expletives. But don't fall for post-purchase wishful thinking, because that's what keeps those companies toying with us instead of honestly selling us full-featured devices.
First impressions are positive here, especially considering price tag. VIdeo looks quite good. ISO performance baffles me a bit since it shares GH2 sensor. Noise is better controlled throughout ISO range on G6, so there seems to be quite a bit of NR going on also after having dialed down to -5. Not necessarily bad thing. Below is lenscap test.
Thanks to all for the information, I almost decided to buy g6 but I still have some questions:-) Could anybody say if the peaking(not focus pointing)is visible via wifi? And one more: can somebody make a clear video of how focus peaking is working on camera lcd in normal light conditions (not in lowlight). Thanks in advance.
Hi Guys, I contacted panasonic.it (cause i'm italian) to ask THE EXACT crop factor of the new g6. They sent me to the manual of the body (LOL). So I noticed that in both the manual of g6 and in the oldness of the gh2 I had, it said, when talking about the objectives, ex. the 14-140, that is equivalent to 28-280. As if the crop factor was 2,0x. But there's written the same thing in both manuals, of g6 and gh2. So I pointed out that this is a mistake, since even online tests show that the crop factor is different. They answered me again, they will contact someone really competent and MAYBE I will know, but on the official facebook page (where also i contacted them), they have written that panasonic factories do not specify more than "about 2x" as crop factor. How sad.
Anyway G6 is not so good as it seemed to be? Yet it seems detailed. The problem of focus peaking in low light situation is so serious?
Thanks
I think some people have too high expectation of G6, since it is a designate G not GH so they tend to cripple it to differentiate from GH, if G is good enough who would want to spend double amount of money on the GH?
(having said that the there are some features I do really want with the G6)
I think they would have good differentiation even if G6 had same codecs as GH3. That one has more convenient manual controls, better build quality etc., and if someone cannot afford GH3, better to sell them a new G6 than have them buy a second-hand GH2? But only Panasonic knows, they must have numbers to back up decisions with G6. And as general consumer reviews are good, our minority opinions probably don't matter to them anyway…
My guess is they're hard at work on GH5, and it'll have focus peaking as G6, same or better sensor as GH3, and same or better codecs as GH3. So G6 may be limited also to "protect" that model.
Anyway, I bought G6 primarily as timelapse camera - it's a decent tool for that purpose - and to check what its 28Mbps 50p mode is good for (not much IMO). If G6 never gets hacked, I'll keep it around to capture cat moments, or give it to a relative who doesn't need high quality video. So it's not much of a loss, but as far as video goes, a disappointment, yes. Tired as heck of 8bit low-bitrate H.264 limits by now, especially as BMPCC with ProRes costs only €200 more than G6. Will probably not buy G/GH series for video in the future, unless Panasonic offers ProRes or AVC-Intra 100 on them, or our usual heroes hack them.
I have done extensive tests with my hacked gh2 (driftwood quantum 9b 150mb/s) and the G6 using the same Carl Zeiss Vario sonnar lens on both and the G6 is much better image wise Panasonic have done a superb job with the G6 - its has a much finer gain structure alot less mosquito noise in the black and dark areas and is just as sharp as the hacked gh2
Its a no brainer the g6 is very very good - just buy one
Here's a short comparison looking at resolving of image. Both shot with zuiko 50mm f1.4 at f5.6. The GH2 has Flow Motion v2 installed in 24p with average bitrate on the tree shot at 94 mb/s. The G6 is in 24p mode avchd with average bitrate of 22 mb/s on the tree shot. I think the G6 holds up very well indeed. Even scaled in very tight the difference isn't much. Fine motion in leaves in shadows on the tree shot show a little compression artifacting on the G6, but less than anticipated from my side. I think this little camera can prove a very versatile tool to bring along.
GH2 wins.
I downloaded the 1080p (pity is crappy youtube).
To my eyes I much prefer the GH2 over the G6. The detail when the wind blows the branches is much better on the GH2. Also the detail in the wood grain is better on the GH2, the G6 looks soft.
At this stage the G6 is out for me. It's a fantastic camera for the price, but I'll look at either a GH3 or BMPCC as an upgrade of the GH2.
Thanks for posting the video. Any chance of sharing a higher bit-rate version?
@andy_lee I'm afraid your opinion that the G6 shoots better looking video than a hacked GH2 is invalid, as you actually own both cameras and took the time to do proper comparison testing. I put much more stock in uninformed blind speculation and downloaded 3rd party clips of unverifiable provenance - they just feel truthier to me, is all.
