Corel Painter X3
  • Painter X3 Feature Highlights
    • Jitter Brushes: Introduce elements of randomness to your brush strokes by adding universal Jitter properties to any brush expression or by using one of the 25 new Jitter brushes
    • Brush Search Engine: Find the perfect brush that inspires you within seconds simply by typing terms in the search bar such as brush names or properties, and ensure they’re what you’re looking for with the enhanced Live Stroke preview
    • Crosshair Cloning: Position the source image beside the clone and take advantage of the crosshairs which mark where you are cloning from, allowing you to focus on the creation
    • Perspective Guides: Speed up the creation of an object with dimension by using the snap tool to draw in 1-,2-, or 3-point perspective and accurately portray spatial depth
    • Smart Brush Controls: Change brush properties more easily now – only the settings that can be tweaked will be displayed in the panel
    • Reference Image Panel: Open a reference image in the new panel to keep a visual source of inspiration within sight as you paint, without toggling between windows
    • Multi-Layer Transformation: Apply a transformation to a selection across multiple layers
    • Flow Maps: Create unique and irregular patterns with this technology that directs wet media across the canvas to produce less saturation at the peaks of the canvas texture and more saturation in the valleys, just like colors would with real-world materials
    More info - http://www.corel.com/painter
