US: Manufacturing survey
  • There may be those among the less than brainwashed lemmingerati out there who have noticed what, as we have pointed out for the past month when reporting on the various manufacturing and regional Fed indices, has been an epic collapse in the appropriate data series. As John Lohman so kindly demonstrates, the two month implosion has been beyond epic, and while certainly the biggest drop in the past decade, may also be the all time worst ever. To the point of this post: the last time we had an economic contraction of this magnitude was back in February of 2008, which was two months into the most acute recession in post-depression history. We are confident that once the groupthink wraps its head around the fact that the auto production based renaissance is not coming, and the economy officially tumbles into the commode of Ben Bernanke's fiat dungeon, the NBER will determine (with an appropriate 12-18 month delay), that the current recession started in April of 2011.
    Source: http://www.zerohedge.com/article/manufacturing-surveys-imply-us-economy-has-entered-second-month-rerecession
  • 1 Reply sorted by
  • Another interesting info:
    In the just completed 2 Year auction (CUSIP: RA0), which just priced at a record low yield of 0.395%, which was a nearly 1 bp tail, all the action was behind the headlines: the Bid To Cover tightened substantially from the 3.46 in May to 3.08 currently, but the kicker was the Indirect take down which at a paltry 22% came at the lowest since February 2008, or even before the Bear Stearns implosion, when central planning was merely a gleam in the central planning cartel's eye. As a result Primary Dealers were left holding the bag on this auction, with 64% of the total notional going to Dealer syndicate, and the balance or 13.5% going to Direct Bidders, also a big drop from the 19.2% in May.
