Hi everyone, I spent a few hours over the past two days creating some Neat Video noise profiles for the GH2 running Moon T8. Currently, I have only created profiles for the 24H, 24L, and 720p60 SH settings, and I use Neat Video version 4. I'm not sure if these profiles will work on other versions, but they may.
If there is enough interest, I can begin to expand the profiles to support more video modes and various hacks beyond Moon T8.
I created a profile for each ISO setting, including secondary settings for the ISO bugged modes (up to 2500 ISO for those) ("clean" is normal, "dirty" is with the bug in case you forget to fix the problem and shoot with the ISO bug)
These profiles were created using the Smooth film mode at -2 -2 -2 -2, though they will probably still work with other modes. What is being picked up here is mostly sensor ISO noise since Moon T8's bitrate is so high.
The end result is that I have been able to recover about 1 - 1.5 stops of extra detail in the shadows on my shots as opposed to it looking like a total mess of noise. If you shoot at crazy high ISO settings, it can't make a shot at 12,800 ISO look like 200 ISO, but as long as your footage is reasonable, you can greatly expand the usable dynamic range of the camera and color grading is that much better.
These profiles should be used FIRST before doing any other processing such as grading, sharpening, scaling, or color correction. Etc...
The 1080p24 profiles seem to work fine on footage shot in variable mode, for example, if you use the 80% mode for slight slow motion.
Here is a link to an Imgur gallery showing what the profiles are capable of: Gallery
Download links:
Reserved...
I did similar thing for GH2, G7 and Nex-5n, presets and profiles are in these links:
https://www.personal-view.com/talks/discussion/15015/gh2-bundle-by-apefos-complete-solution-for-gh2
Thanks for the links, apefos!
OP updated with 1080p24 EX24H (Ex. Tele Convert mode) profile.
Good afternoon ! Where to download moon8 ?
