Insta360 One R Camera
    Insta360 One R (360 module)
    • two fisheye lenses, F2.8 each
    • Photos at 6080 x 3040 in JPEG or DNG raw
    • Video modes
      • 5760 x 2880, 30fps
      • 3840 x 1920 @ 50fps
      • 3840 x 1920 @ 30fps
      • 3008 x 1504 @ 100fps
    • 100mbps, H.265
    • OLED touchscreen
    • 3008 x 1504 @ 100fps fast mode
    • 6-axis gyro-based image stabilization
    • Voice control
    • Waterproof
    • WiFi and Bluetooth LE 4.0
    Most probably presentation will be on CES 2020.
    570 x 372 - 23K
    456 x 513 - 22K
    453 x 491 - 30K
    318 x 334 - 14K
    800 x 600 - 42K
  • 56 Replies sorted by
  • So it looks to be a modular 180/360 camera? With a snap on lens cover that... reduces the FOV? I guess it looks interesting if the individual modules are cheaper but I doubt that from Insta 360.
    800 x 562 - 33K
  • Camera introduced
  • AI-powered Auto Frame makes editing 360 video easy.
    Innovative camera maker Insta360 today announced ONE R, an adaptive action cam whose unique interchangeable-lens design enables 360-degree capture, standard 4K wide-angle capture, and use of a groundbreaking 5.3K 1-inch sensor --- all with a single device.
    The concept is simple --- one battery, one processor and a selection of quick-swapping lens Mods. In an instant, ONE R transforms from a dual-lens 360 shooter to a standard action cam. ONE R currently offers three ways to shoot with three available lens Mods --- the Dual-Lens 360 Mod, the 4K Wide-Angle Mod and the 1-Inch Wide Angle Mod co-engineered with Leica.
    The 1-Inch Wide Angle Mod achieves the best performance ever in an action camera, combining a 1-inch sensor with the legendary optical expertise of Leica and 5.3K resolution --- in a compact, rugged body backed by Insta360's signature FlowState stabilization.
    ONE R is available to order today via Insta360.com and select retailers worldwide, including Best Buy.
    The right tool for every job.
    ONE R is designed to give creators, athletes and adventurers a single tool that can adapt to any shoot.
    In terms of creative freedom, nothing beats a dual-lens 360 camera. It unlocks the ability to reframe shots after the fact, ensures that users never miss the action, and enables unique techniques such as drone-like aerial angles. But for scenes in which action is concentrated in one direction, a reframed shot from a 360 camera still doesn't achieve the same level of quality and resolution as a specialized single-lens shooter.
    These two camera formats have unique strengths and tradeoffs --- just as telephoto and wide-angle setups on an SLR camera have equal but opposite strengths. The only way to take advantage of both formats is with an easy, efficient way to switch from one to the other on the fly. ONE R is just that.
    Best quality ever in an action cam.
    ONE R redefines what's possible with an action cam. Each of its three available Mods unlock breakthrough imaging and quality.
    Dual-Lens 360 Mod: This Mod supports 5.7K capture on two lenses that cover every direction at once. It enables a real-time 360-degree preview on ONE R's touchscreen, while innovations like Color Plus, HDR video and Night Shot achieve the best color accuracy and low-light performance in any consumer 360 camera.
    4K Wide Angle Mod: Ready for 4K@60fps, this Mod captures crisp, vibrant, stabilized action and supports up to 8x slow mo. Its reversible design lets you flip the touchscreen from back to front in a snap --- perfect for getting real-time feedback when filming yourself.
    1-Inch Wide Angle Mod co-engineered with Leica: This Mod achieves a level of quality never before seen in an action cam. The 1-Inch Wide Angle Mod uses a best-in-class 1-inch sensor to capture brilliant 5.3K video and 19MP photos even in complex lighting conditions. Premium performance in a device that's ready to go anywhere - the 1-Inch Wide Angle Mod is a game-changer.
    Leica worked closely with Insta360 on the optical engineering and industrial design of the 1-Inch Wide Angle Mod, and contributed its unmatched expertise in image quality and color reproduction.
    Smooth moves. Even in the dark.
    The ONE R uses a fully upgraded FlowState stabilization algorithm to achieve gimbal-like stabilization whether you're shooting in 360 or with a standard wide angle. Using a smart scene-detection algorithm, ONE R outclasses the competition with stabilization that holds steady even in low-light scenes.
    Waterproof whenever.
    ONE R is IPX8 waterproof to depths of 5 meters (16.4 feet) straight out of the box. For those who want to go deeper, a Dive Case enables descents of up to 60 meters (197 feet).
    Voice control.
    Voice control lets you control ONE R with a few simple commands. If ONE R is mounted on a helmet or out of reach, just give it a shout.
    Auto Frame changes the game.
    The best thing about shooting 360 video is that you capture an infinite number of possible angles and edits. The worst thing about shooting 360 video is that you capture an infinite number of possible angles and edits. If only there were some kind of artificial intelligence that could analyze a scene in every direction at once to find the most interesting moments and angles.
    Enter Auto Frame. Insta360 has developed its own computer vision algorithm to identify the best parts of any 360 video and recommend them to creators. There's still plenty of choice, but the ONE R app's Auto Frame feature helps you quickly narrow down the shots worth considering and does the reframing for you.
    Deep Track.
    AI-powered computer vision also enables ONE R's mind-blowing tracking capabilities. When editing 360 video, creators can simply select a subject to follow with a tap. The ONE R app will automatically keep it locked in center-frame. Even if a subject is obscured by an obstacle, ONE R's algorithm will remember it and start tracking again as soon as it reappears.
    And if you don't want to wait for post-production to choose your subject, you can also use Deep Track in real time. ONE R's unique "Point to Track" feature lets you lock onto a subject with the voice prompt "Mark that!". The next time you connect to your camera, you'll get an automatically reframed shot that follows your chosen subject - it's like having a cameraman with you wherever you go.
    No drone. No problem.
    ONE R brings back Insta360's endlessly fun and versatile Invisible Selfie Stick feature. Easily capture aerial angles and video-game-style third-person views by making your camera grip invisible. Invisible Selfie Stick is only supported when using the Dual-Lens 360 Mod.
    Low light. Done right.
    ONE R offers a range of both hardware and software upgrades to achieve best-in-class low-light performance. New Night Shot mode captures low-light photos that pop, while automatic de-noising preserves detail in low-light video.
    ONE R also supports HDR modes for both photos and video, and creators can take advantage of Color Plus to do an automatic, one-touch color grade that brings out brighter, more vibrant hues.
    When it comes to color reproduction and low-light performance, the 1-Inch Wide Angle Mod co-engineered with Leica is in a class of its own. Its 1-Inch sensor brings out highlights and shadows in vivid detail. Vloggers will be tempted to leave the rest of their kit at home.
    Sounds good.
    Every ONE R build comes standard with two onboard mics and an automatic wind-reduction algorithm that achieves great sound straight off the camera. However, its USB Type-C port and top-mounted Accessory Shoe also allow for easy third-party 3.5mm mic connection.
    Infinite possibilities.
    The ONE R app comes with a range of new editing features designed to help creators take advantage of all its capabilities. The TimeShift hyperlapse effect popularized by ONE X can now be completed with a couple taps, and a new pose-detection algorithm lets creators instantly identify and extract every frame of a clip in which they strike a similar posture --- enabling mind-bending stop-motion effects that used to take hours of work.
    New Starlapse mode automatically calibrates exposure settings to capture stunning time-lapses of the night sky - creators just pick a time and a place and hit record. The ONE series' signature Bullet Time effect has also been upgraded with a smart horizon-leveling algorithm.
    FlashCut auto-editing.
    FlashCut is the ONE R app's content-aware editing algorithm. First, it finds shots based on a theme set by the creator --- like food, travel or pets. Then it combines them on beat into a stylish edit. FlashCut can filter and combine footage captured by any ONE R build --- 360 or standard.
    More Mods.
    ONE R doesn't stop at three Mods. Its unique design enables a huge range of efficient add-ons and upgrades. The standard Battery Base can be swapped for a double-size Boosted Battery Base for extended shooting.
    Meanwhile, Insta360 today also announced the groundbreaking Insta360 ONE R Aerial Edition, which offers a specialized mounting system to make supported drones completely invisible and captures an unobstructed, airborne 360-degree view.
    An Edition for every mission.
    ONE R is all about choice. Creators can purchase exactly the combination of gear that suits their needs. However, Insta360 also offers a range of prepackaged Editions that give creators everything they need to get started with some of the most powerful combinations of Mods.
    Insta360 ONE R Twin Edition brings together two great ways to shoot - the Dual-Lens 360 Mod and 4K Wide Angle Mod - in one convenient package for $479.99 USD; Insta360 ONE R 1-Inch Edition comes standard with the premium 1-Inch Wide Angle Mod co-engineered with Leica, and retails for $549.99 USD; and Insta360 ONE R 4K Edition offers creators all they need to enjoy the versatile 4K Wide Angle Mod for $299.99 USD.
    800 x 517 - 42K
    800 x 561 - 37K
    800 x 585 - 51K
    800 x 573 - 43K
  • PR considering Leica
    Leica and Insta360 Announce Strategic Partnership to Reinvent the Action Cam The companies co-engineered the new Insta360 ONE R, a groundbreaking adaptive action camera that offers a premium 1-inch sensor and advanced stabilization.
    Today Leica Camera AG and Insta360 announced a partnership aimed at bringing true innovation and state-of-the-art imaging quality to the action camera and 360-degree camera spaces.
    The announcement coincides with the launch of the Insta360 ONE R, an adaptive action camera that uses a unique interchangeable camera module to combine the creative freedom of 360-degree capture with the precision and resolution of traditional single-lens shooting.
    Leica and Insta360 co-engineered the premium Insta360 ONE R 1-Inch Edition, which offers creators a 5.3K 1-inch sensor to achieve image quality and dynamic range never before seen in an action cam, together with Insta360’s signature FlowState stabilization. This 5.3K wide-angle lens can be instantly swapped for a dual-lens setup that captures action in all directions at once and unlocks a range of creative techniques only possible with a 360-degree field of view.
    The Insta360 ONE R 1-Inch Edition is the first result of Leica and Insta360’s shared vision of craftsmanship and innovation in an era when cameras have a more central role in culture and communication than ever before.
    ‘With Insta360, we have found the right partner to bring the decades of Leica optical and digital imaging expertise into a new product segment. We think that Insta360 has an extremely high level of know-how in the software sector - especially in the field of 360-degree acquisition technologies. The aim of our cooperation is to develop innovative technologies under the highest image and quality standards, trying to push the limits of what is technically possible’, says Matthias Harsch, CEO of Leica Camera AG.
    JK Liu, Insta360 Founder, said: “For more than a century, Leica has never stopped pushing the boundaries of what’s possible with a camera, and it’s never lost sight of a guiding ethos of craftsmanship and quality that inspires photographers to push their own work further. They are the ideal partners to join us in perfecting a new generation of cameras that serve users at every step of the creative process — from capture to editing to sharing. Combining the expertise in optics and imaging design of Leica with Insta360’s unique portfolio of innovations, including gimbal-free stabilization and smart editing software, will allow both brands to redefine categories and realize the potential of new camera formats and modes of capture.”
    735 x 727 - 50K
    650 x 317 - 22K
  • Aerial Edition sample
  • Drone usage
  • Night mode
  • 15 tips and tricks
