Aputure 300X Bi-Color Light
  • 7 Replies sorted by
  • Aputure 300X (Daylight setting), Measurement using CV600, Russian Lab processing
    Focus on TM30 and CIE 224 and look for color distortion and Rf values.
    300X is good light with light quality suitable for videos. But nothing to write home about, on par or even worse with typical cheap Chinese COB lights now.
    Color temperature
    CRI color quality
    CQS color quality
    TLCI 2012
    TM30 color quality
    TM30 details
    CIE 224 2017
    800 x 425 - 31K
    800 x 413 - 56K
    759 x 517 - 60K
    709 x 443 - 57K
    757 x 475 - 62K
    800 x 328 - 46K
    685 x 630 - 52K
    800 x 262 - 64K
    800 x 457 - 47K
    506 x 507 - 47K
    788 x 373 - 41K
  • In maximum-output mode, the 300X develops around 9000lx at 2800K and 11500lx at 6500K. Cooler LEDs tend to have higher output since they’re converting less of the blue emitter, and this is normal. In maximum-output mode, the 4200K setting achieves perhaps 16000lx. That’s still less than a 300D at full power, but not unreasonable given the involvement of warmer-tuned emitters. Selecting constant-output mode drops the 4200K setting to around 8500lx, more or less as we’d expect. It’s always the case that constant-output mode will noticeably limit output in the middle and cooler ranges, and Aputure’s menu option makes sense.
    At no time does TLCI fall below 91.2, and even then it’s at the difficult 5% output level, which also provokes the poorest R9 reading at a still-fine 79. At 50% output, lowest TLCI is 97.3 and R9 remains at 80, even at the cooler end of the CCT range. At 3200K, which tends to be easier to get right, the 300X achieves 98.4 TLCI, 93 R9, and 90 R12.
    https://www.redsharknews.com/a-deep-dive-into-aputures-new-300x-light
  • Thanks MileLinn for sharing this video, it’s a very nice review. I was looking for tests outdoor and this video show that.
