https://www.magix.com/us/music/samplitude/
Changes in version 15.0.0.38:
Plug-in browser
- Plug-ins can be added via plug-in browser after click on empty plug-in slot
- VSTi or Rewire instruments can be added on a track, too
- the browser can also be opened from main menu
- Functions
- view by location / vendor / category
- search function
- favorite function
- double click on "+ new folder" creates a new folder
- plugins can be moved into new folder via drag'n'drop
- recently used
- Plug-in slot menu
- 'favorites' and 'recently used' entries can be accessed via menu
- commands to replace or delete the existing plug-in
- old plugin menu via ini entry available [Factors] FxBrowserOptions=1
- Keyboard handling
- default shortcut: B
- search: Ctrl+F
- extend / collapse current folder: cursor left / right
- extend / collapse all entries: Ctrl + cursor left / right
- keyboard shortcuts for tabs
- 'favorites' and 'recently used' - entries can be deleted by pressing del key
Automation
- Automation lanes
- new automation display mode "Lane and object automation" displays additional lanes for track automation, while object automation is still visible and editable in original tracks
- automation parameters and values are displayed in track head
- automation points can be selected via lasso from left to right (not reversed as in audio tracks)
- automation points of several lanes can be moved together
- lanes are created automatically while writing automation data
- Automation Editing
- special key can configured for temporary change to automation drawing mode
- automation points react to mouse movements, even after leaving the track
- automation points can be moved beyond neighbors (there's a snap range for creating automation jumps)
- lines between automation points can be moved vertically. Doing this inside a range moves the automation data of the whole range vertically (creates new nodes at the edges)
- New option: "Thin out automatically" for automatic optimization after drawing or writing automation data
Performance
- "ASIO priority boost" option now also available for current Windows operating systems (uses MMCSS)
- multi core handling with increased ASIO stability and reduced CPU load by calculating non-monitoring tracks and VSTi in advance
- support for up to 32 CPU cores
Arranger
- no automatic fade in/out after loading objects anymore, automatic crossfades are created when putting objects together
- quick access to mouse mode menu via Shift+right mouse click, right + left mouse click or Shift + context menu key in arranger
- new option implemented as menu command: auto track maximize
- working when clicking into track head or activating via track manager
- size of maximized track can be changed and is used for any other tracks
- skins
- Samplitude default skin changed to "Carbon"
- new skin features
- improved display of lasso and range (semi transparent)
- new object handles
- anti-aliased fade display
- multiselection of tracks by clicking in "empty space" available, not only on track name
- improved lasso function in empty space underneath last track + improved vertical scrolling up and down
- accelerated drawing when a lot of small objects are displayed
VST setup
- support for more than one VST folder
- display of system paths in directory tree
- accelerated VST scanning with crash protection
- option to abort scanning (e.g. for hanging plug-ins)
MIDI / Instruments
- additional Vita Solo Instruments (instruments of former versions can be used as well)
- Analog Synths 2
- Century Keys
- Grand Piano
- Orchestral Ensemble
- Power Guitar
- Sansula
- Pro X4 Suite only
- Concert Guitar
- Pop Brass
- Upright Bass
- Revolta update with several new presets
- MIDI Editor
- Controller
- selection based on horizontal and vertical range now
- new tool for scaling and moving selected controllers
- new command for smoothing / available via MIDI Editor toolbar and menu
- drawing now also works from right to left
- more than 1 note can be deselected via Ctrl + mouse drawing
- copied MIDI data can be inserted into arranger as new object
- improved undo handling inside velocity dynamics dialog (triggered with Ctrl-Z)
- Plug and Play detection of MIDI input devices
- MIDI objects can be extended to the left in arranger
- accelerated repeated display of VSTi - preset-menus (concerning all output menus e.g. mute/solo)
Lyrics marker
- new marker type, which can be switched in marker manager
- current and next marker event can be selected in time display
- can be imported from / exported as text / lyrics events in MIDI / Karaoke files
- display in MIDI editor score (use 'score properties' in Program Preferences and 'page settings' to switch on/off)
- lyrics marker can be displayed in arranger (use 'view options' in Score Properties and 'VIP' to switch on/off)
More
- default usage of all available ASIO channels, no initial restriction to 8 anymore
- ASIO device names supplied by driver are used, e.g. for mono handling in surround setup dialog
- new project length for projects based on templates can be adjusted
- improved scrubbing for Eucon protocol
- new option: auto save after record stop
- new time display:
- position relative to file / timestamp of selected object
- keyboard handling
- 2 new default - shortcuts
- Shift + - : range over all selected objects
- Strg + # : metronome on/off
- improved keyboard handling in system settings
- several bugfixes
