Table of Contents
Introduction
The GUI for fwtool is built using standard WIN32 API.
Updates
Preview 3: Planned
Redirect the console output to the UI.
Preview 2: Planned
Add decryption.
Implement the progress bar.
Multi-threaded GUI. The decryption or encryption will work in a separate thread so that the UI won't freeze.
Build fwtool as dll.
Add Code::Blocks project files.
Preview 1: 2013-06-04
This version has a basic UI as the initial design, the only working function is decryption. The source contains Code::Blocks project settings, I will adapt it to pellesc project in next release.
Source: check VCS
Binary: fwtool_gui_bin.7z
The design
We want it to be as simple as possible. All the functions will be put in a single window. Below is the current design:
Useful Resources
For WIN32 GUI programming, check http://www.winprog.org/tutorial/
For IDE, I prefer Code::Blocks, check http://www.codeblocks.org/
Form designer and code generator for Win32 API - 104_visg0951.zip
