AN "Valkyrie", GOLGOP3-13, GOP3ZILLA, natural, Freeze-less Reliable All-round GOP3 Settings :-)
  • 1001 Replies sorted by
  • GOLGOP3-13-A_Candidate 3 low light footage sample
    HBR and 24p
    nos(0,0,0,0) SS50 or 100 AWB
    panasonic 20mm F1.7(wide open) ISO160-800
    panasonic 12-35mm F2.8(wide open) ISO400-1600
    no color grading
  • @Mrhechang Thanks always mate! Based on the feedback from you, I am further improving GOLGOP3-13 now. :-)
  • @Shon No, I am speaking of shutter speed. I was exposing the shots longer than usual so movement blurred (I hope now I get the vocabulary right).
  • @bkmcwd I am uploading some recent lowlight shotsto my Dropbox. Check your mailbox ;)
  • I came back. Thanks, @Tobsen! I finished downloading. Looks so coooool!!! :-)
  • @bkmcwd
    I used "Valkyrie Flat4 'Apocalypse Now' with Driftwood's Flat 4 Matrix" 24H mode.
    Thanks for amazing quality settings and your hard work!!
    *FILM MODE is NOS.(-2,0,0,-2) and the lens is LUMIX G X VARIO 35-100mm/F2.8
    *SANDISK Extreme Pro SDXC UHS-I (95MB/s) 64GB
  • @har_k Many thanks always for testing my settings, mate! :-) A new lens also seems to be wonderful.
  • Thanks for your great setting bkmcwd! GOP3ZILLA Standerd V3 beta 24H&SH mode smooth -2,-2,-2,-2 ZuikoDigital ED12-60SWD ZuikoDigital ED50-200SWD
    TimeLaps Olympus OM-D E-M5 M.ZuikoDigital 9-18 ROKINON 7.5mm f3.5 FishEye
  • @misunhd Amazing work man!!! Thanks always for using my settings, mate. :-)
  • @ GOLGOP3-13 lovers :-)
    "GOLGOP3-13-A_Candidate 4" and "GOLGOP3-13-MAX_Candidate 4"
    I release the each 4th candidates for "GOLGOP3-13-A" and "GOLGOP3-13-MAX" settings.
    These have changed also including the matrix from the former candidates.
    The main changed parts are "having changed all matrices into I=P=B", and "improvement in freezing-proof performance" especially in HBR. I think that the bit rate in HBR probably becomes low rather than a former candidate. However, the freezing issue at the moment of the focus was solved also in Panny lens use.
    Please try them! And many thanks for your feedbacks!
    Special thanks to @Mrhechang and @syoushow! :-)
    NOTE:
    *Although bit rate setups are quite high, the bit rate which actually appears are lower than these. Since the actual bit rate changes by the object to shoot, please confirm by yourself.(Max bitrate : about 110M in 24p, about 75M in HBR.)
    *These two settings are completely the same except 24p.
    *24H and 24L are high quality 3GOP setting with mega size I-frames in GOLGOP3-13-A.
    *24H and 24L are high quality 3GOP setting with super mega size I-frames in GOLGOP3-13-MAX.
    *24p80%(30p) is available in 24H & 24L both.
    *60i, 50i, HBR30p and HBR25p are also high quality and stable 3GOP settings.
    *720/50p and 720/60p are 6GOP and 9GOP. It has tuned up so that the bit rate at the time of motion may go up rather than the time of statics.
    *In camera playback is available in all rec mode except 24p in GOLGOP3-13-MAX, at least available after reboot the camera.(Not tested full yet, but probably)
    *EX Tele, iA mode work.(Not tested full yet, but probably)
    *Spanning in 24H, 24L with SanDisk 95MB/s 64GB SDXC Card. In other rec mode, need test.
    Please DL original raw data to look the REAL IQ. *This video is only sample for image quality.
    bkmcwd GOLGOP3-13-A_Candidate 4.zip
    1K
    bkmcwd GOLGOP3-13-MAX_Candidate 4.zip
    1K
    1298 x 633 - 481K
  • @ GOP3ZILLA lovers :-)
    "GOP3ZILLA_3_Candidate 3"
    I release the 3rd candidate for "GOP3ZILLA_3" setting.
    In this version, the freezing issue at the moment of the focus in HBR or 720p is canceled.
    Please try it! And many thanks for your feedbacks!
    If this is also still unstable, I will further adjust.
    *About 24p, it is completely the same as former candidates.
    NOTE:
    *Although bit rate setups are quite high, the bit rate which actually appears are lower than these. Since the actual bit rate changes by the object to shoot, please confirm by yourself.(Max bitrate : about 100M in 24p, about 75M in HBR.)
    *This is the simple setting which harnessed the feature of the stock as it was.
    *24H and 24L are high quality 3GOP setting with mega size I-frames.
    *I especially recommend you use with SanDisk 95MB/s 64GB SDXC card. However, I have got the report that the card of other classes 10 can also be used satisfactorily.
    *In camera playback is available in all rec mode, at least available after reboot the camera.(Not tested full yet, but probably)
    bkmcwd GOP3ZILLA_3_Candidate3.zip
    867B
  • UPDATE(2012/11/06)These candidates of GOLGOP3-13 are upgraded as official settings as a result of verification.
    "GOLGOP3-13-A_Candidate 4b" , "GOLGOP3-13-MAX_Candidate 4b" , "GOLGOP3-13-A_Candidate 5" and "GOLGOP3-13-MAX_Candidate 5"
    I release the next candidates for "GOLGOP3-13-A" and "GOLGOP3-13-MAX" settings.
    All of these matrices are the same as C4. The main changed parts are having further raised freeze tolerance especially in HBR.
    The difference between C4b and C5 is a difference in how depending on which the bit rate appears. I am not sure which candidate is the better. Please judge.
    I think that the freezing issue at the moment of the focus was solved nearly perfectly also in Panny lens use.
    NOTE:
    *In each candidate, 'MAX' versins and 'A' versions are completely the same except 24p.
    Please DL original raw data to look the REAL IQ. *These videos are only samples for image quality.
    bkmcwd GOLGOP3-13-A_Candidate 4b.zip
    1K
    bkmcwd GOLGOP3-13-MAX_Candidate 4b.zip
    1K
    bkmcwd GOLGOP3-13-A_Candidate 5.zip
    1K
    bkmcwd GOLGOP3-13-MAX_Candidate 5.zip
    1K
    1299 x 637 - 564K
    1298 x 633 - 563K
  • NEW!
    bkmcwd Valkyrie 444 TYPE-ZERO2 Candidate1.5c 'Apocalypse Now' with cbrandin 'Pure Original 444 Matrix' and 'Modified 444 Matrix' - seta.ini - Released 02/11/2012
    This is the version which adjusted safer from C1.5b in HBR and 720p.
    Please try it! And I am very glad if feedback can be got.
    *If this is also still unstable, I will further adjust.
    Special thanks to @har_k, @syoushow, @Tobsen, @peternap, @jul, @towi, @flaschus, @Berlin and @Mrhechang! :-)
    Of course, thanks to @cbrandin and KING @driftwood!
    *24p is the same as C1.5b.
    • Superb-looking simulated 444 matrix from cbrandin
    • Modified 444 matrix from my BETA Team in Japan is adopted in HBR/1080i and 720p modes.
    • Upto 140M for Top Quality 1080p24 at Q18
    • Upto 140M for Top Quality 1080p30 at Q18 in 24L mode with 80% Slow-Motion Mode (No Sound)
    • Upto 75M for Top Quality HBR/FSH modes
    • Upto 75M for Top Quality 720/50p modes
    • Upto 55M for Top Quality 720/60p modes
    • Extremely reliable top performance in AVCHD 24H and 24L
    • 80% Slow-Motion is available in 24L only
    • Fully working iA and iDynamic modes if you require them
    • Beautiful 3 GOP bringing short GOP style detail & movement-rendition in 24p and 1080i
    • Bush of Death / Death chart tested.
    • Wonderful Pasadena Pulse Audio Patch V2 B2, by Per Lichtman
    • Top quality 2K mjpeg Mode in HD by Nick Driftwood
    • In camera playback is sometimes not available in 24p. In other mode, available after reboot the camera.
    bkmcwd Valkyrie 444 TYPE-ZERO2_Candidate1.5c 'Apocalypse Now' with cbrandin 'Pure Original 444 Matrix' and 'Modified 444 Matrix'.zip
    1K
  • @All @flaschus
    Do I need to improve Valkyrie Flat4 further? Are there those who are using VF4? If required, I also further improve this. :-)
  • @bkmcwd Will try out the Valkyrie Flat4 very soon. I'm currently using Apocalypse Boom and like it a lot. Is Valkyrie Flat4 designed to be similar to this? What would you say are the similarities and differences between Apoc Now Boom and Valkyrie Flat4? Thank you.
  • @matt_gh2 Many thanks for trying VF4! :-)
    Honestly, since I myself have not verified fully yet about the image quality of Flat4, I am not sure. However, since @flaschus has already used it, I think that he is detailed about it. My having tried hard about Flat4 is making it stabilized, adopting this matrix in all rec modes. It is designed as 3GOP structure in 24p, HBR and 1080i so that the big I frame which naturally cannot be used with the Intra structure can be used.
    When I imagine from the result of 444 pure matrices of Chris, at Flat4 matrix as it is, artifacts may appear in HBR or 720p. Of course, this will be influenced by the lens used. Supposing I improve VF4, there are two steps. As the first step, if necessary, it is the work which optimizes a matrix to modes other than 24p. As the second, it is the work which stabilizes it infinite. I think that instability remains a little in HBR since VF4 present is somewhat old setting. Although I think that I will improve at least this instability but, I think that I will cleave my resource to other work if unnecessary.
    If you take to VF4, I will improve, but how are you?
  • UPDATE(2012/11/06)This candidate of GOP3ZILLA3 is upgraded as official settings as a result of verification.
    "GOP3ZILLA_3_Candidate 4"
    I release the 4th candidate for "GOP3ZILLA_3" setting.
    In this version, the freezing issue at the moment of the focus in HBR or 720p is canceled nearly perfectly. I think that this is further stable from C3.
    NOTE:
    *This is the simple setting which harnessed the feature of the stock as it was. I recognize this to be the normal evolution version of the stock.
    bkmcwd GOP3ZILLA_3_Candidate4.zip
    868B
    1296 x 633 - 563K
    1296 x 633 - 533K
  • @bkmcwd thx for all your awesome work!
  • @Mirrorkisser Thank YOU mate! I am in the strengthening weeks of the improvement in reliability now. I aim at the settings which never freeze or stop with 95MB/s SDXC. :-)
  • @bkmcwd I used C1.5b for the last week. It looks good and I didn't have problems in camera - using Sandisk 32GB 45MB/s card. I only have some problems playing in the PC - the video slows down every 2seconds - but that is probably a player/codec problem. I didn't have time yet to transcode to something like prores and test, I did rewrap but it plays the same.
  • @kankala Many thanks for your report! Yes, in ordinary usage, C1.5b may also be satisfactory. However, I improved just in case. Please also try it. :-)
  • @bkmcwd: what is the improved candidated over c1.5b? i thought that was the latest valkyrie? thx
  • @Mirrorkisser
    I am sorry that my English is unclear. In HBR of C1.5b, there was a problem which the camera freezes the moment of focusing. Since this issue is influenced by your use lens and conditions, it may hardly become a problem practically. However, it is C1.5c that I canceled this issue just in case. Again, improving points are reliability and stability. Did it get across to you? :-)
  • yes! thank you very much for the explanation. i will try c.1.5 c immediately as 1.5b was my favourite before :)
  • @Mirrorkisser Many thanks for using C1.5b and C1.5c. :-)
Start New Topic
Howdy, Stranger!
Sign In Register as New User
Tags in Topic
Top Posters
