                  Announcing version 2.3 of StreamParser. This is a fairly significant update. There are numerous refinements and improvements. The major new feature is a new analysis tool based on the JM decoder. It can provide lots of information about a stream; like frame quality metrics, quantization tables in use, deblocking filtering, and many other things. It replaces h264_parse in the previous version (which had too many limitations).
Many thanks to Lee Powell and Nick Driftwood - they were super helpful in testing all of the new features.
As always, remember to uninstall previous versions first.
Chris
                  Version 2.4 of StreamParser is now available. @duartix had requested that additional information about video frames be added. This update adds separate statistics about I, P, and B frames to the Information Panel. This should be useful for determining how bandwidth is allocated between different frame types. Thanks for the suggestion @duartix!
                  Brilliant idea.
You are too kind.
Thanks! This shall be put to very good use!
Very nice idea! Thanks.
What am i missing , ive been sittin here for 20 min and it wont install or open up or what ever.. can someone help.
We'll need more information - saying nothing works isn't much to go on.
@jclmedia it worked for me.
You have to unzip the file into a folder and run setup. Also, it's a Windows program - I don't think it will work on Apple computers. Also, if you don't have .NET installed it will need to download it from Microsoft - so you will need an Internet connection.
Announcing StreamParser 2.5.
This version has many new features to help analyze the quality of video streams.
Also attached is documentation. Yep... you read right - there's actually some documentation now!
Chris
                  @cbrandin Wow!!! It's very useful! Thanks for your hard work. :-)
