Logarist now supports Premiere Pro and Premiere Elements with a free color correction plugin.
Supported Video Applications:
Supported Camera Color Spaces:
Any plans for OFX plugin for Magix stuff?
But the VisionColor LUT Plugin is an OFX plugin, if you need a way to load LUTs.
Well, editors have native way to load LUTs, so no need.
@balazer First of all, thanks a lot @balazer for all the work creating this tool that looks really interesting. I used to work on FCPX but did my last project (50min) on Premiere with the older version CS6. I would like to try out Logarist and installed it, but it does not show up in the effect window under, Video Effects/Color Correction. Any ideas what could be the problem?
@gameb, for Premiere Pro versions earlier that CC, you need to use a different plugin folder.
For Premiere Pro CS6 in Windows, during the Logarist installation, specify "C:\Program Files\Adobe\Common\Plug-Ins\CS6\MediaCore" as the plugin folder.
For Premierie Pro CS6 on Macs, after Logarist installation, manually copy /Library/Application Support/Adobe/Common/Plug-ins/7.0/MediaCore/Logarist.plugin to /Library/Application Support/Adobe/Common/Plug-Ins/CS6/MediaCore/ .
@balazer Great! Thanks again, that worked perfectly on my Mac.
@balazer did you use premiere pro SDK for premiere elements? I thought elements did not support plugins.
@zcream, I used the After Effect SDK, targeting Premiere plugin APIs. Premiere Pro and Premiere Elements are supported.
